tiny usb issue
varung
tiny usb issue
Postby varung » Tue Oct 08, 2024 6:16 am
idf.py build
Executing action: all (aliases: build)
Running ninja in directory /home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build
Executing "ninja all"...
[1/1] cd /home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/.../esp-idf/examples/espidf_projects/touch_espnow/build/bootloader/bootloader.bin
Bootloader binary size 0x5260 bytes. 0x2da0 bytes (36%) free.
[2/4] Linking CXX executable touch_espnow.elf
FAILED: touch_espnow.elf
: && /home/vgurav/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32s3-elf-g++ -mlongcalls -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -Wl,--cref -Wl,--defsym=IDF_TARGET_ESP32S3=0 -Wl,--Map=/home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/touch_espnow.map -Wl,--no-warn-rwx-segments -fno-rtti -fno-lto -Wl,--gc-sections -Wl,--warn-common -T esp32s3.peripherals.ld -T esp32s3.rom.ld -T esp32s3.rom.api.ld -T esp32s3.rom.libgcc.ld -T esp32s3.rom.wdt.ld -T esp32s3.rom.version.ld -T esp32s3.rom.newlib.ld -T memory.ld -T sections.ld CMakeFiles/touch_espnow.elf.dir/project_elf_src_esp32s3.c.obj -o touch_espnow.elf -L/home/vgurav/esp/esp-idf/components/soc/esp32s3/ld -L/home/vgurav/esp/esp-idf/components/esp_rom/esp32s3/ld -L/home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/esp-idf/esp_system/ld -L/home/vgurav/esp/esp-idf/components/esp_phy/lib/esp32s3 -L/home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3 esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/app_trace/libapp_trace.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/unity/libunity.a esp-idf/cmock/libcmock.a esp-idf/console/libconsole.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_driver_cam/libesp_driver_cam.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/esp_hid/libesp_hid.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/esp_https_server/libesp_https_server.a esp-idf/esp_lcd/libesp_lcd.a esp-idf/protobuf-c/libprotobuf-c.a esp-idf/protocomm/libprotocomm.a esp-idf/esp_local_ctrl/libesp_local_ctrl.a esp-idf/espcoredump/libespcoredump.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/fatfs/libfatfs.a esp-idf/json/libjson.a esp-idf/mqtt/libmqtt.a esp-idf/nvs_sec_provider/libnvs_sec_provider.a esp-idf/perfmon/libperfmon.a esp-idf/spiffs/libspiffs.a esp-idf/touch_element/libtouch_element.a esp-idf/usb/libusb.a esp-idf/wifi_provisioning/libwifi_provisioning.a esp-idf/espressif__tinyusb/libespressif__tinyusb.a esp-idf/espressif__esp_tinyusb/libespressif__esp_tinyusb.a esp-idf/espressif__usb_host_hid/libespressif__usb_host_hid.a esp-idf/main/libmain.a esp-idf/app_trace/libapp_trace.a esp-idf/unity/libunity.a esp-idf/esp_https_server/libesp_https_server.a -u esp_system_include_coredump_init -u nvs_sec_provider_include_impl esp-idf/protocomm/libprotocomm.a esp-idf/console/libconsole.a esp-idf/protobuf-c/libprotobuf-c.a esp-idf/json/libjson.a esp-idf/esp_hid/libesp_hid.a esp-idf/espressif__esp_tinyusb/libespressif__esp_tinyusb.a esp-idf/fatfs/libfatfs.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/espressif__tinyusb/libespressif__tinyusb.a esp-idf/espressif__usb_host_hid/libespressif__usb_host_hid.a esp-idf/usb/libusb.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a esp-idf/xtensa/libxtensa.a esp-idf/esp_driver_gpio/libesp_driver_gpio.a esp-idf/esp_pm/libesp_pm.a esp-idf/mbedtls/libmbedtls.a esp-idf/esp_app_format/libesp_app_format.a esp-idf/esp_bootloader_format/libesp_bootloader_format.a esp-idf/app_update/libapp_update.a esp-idf/esp_partition/libesp_partition.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/esp_mm/libesp_mm.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/hal/libhal.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/soc/libsoc.a esp-idf/esp_hw_support/libesp_hw_support.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/pthread/libpthread.a esp-idf/cxx/libcxx.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_driver_gptimer/libesp_driver_gptimer.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/esp_driver_uart/libesp_driver_uart.a esp-idf/esp_event/libesp_event.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_driver_pcnt/libesp_driver_pcnt.a esp-idf/esp_driver_spi/libesp_driver_spi.a esp-idf/esp_driver_mcpwm/libesp_driver_mcpwm.a esp-idf/esp_driver_i2s/libesp_driver_i2s.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_driver_sdmmc/libesp_driver_sdmmc.a esp-idf/esp_driver_sdspi/libesp_driver_sdspi.a esp-idf/esp_driver_rmt/libesp_driver_rmt.a esp-idf/esp_driver_tsens/libesp_driver_tsens.a esp-idf/esp_driver_sdm/libesp_driver_sdm.a esp-idf/esp_driver_i2c/libesp_driver_i2c.a esp-idf/esp_driver_ledc/libesp_driver_ledc.a esp-idf/esp_driver_usb_serial_jtag/libesp_driver_usb_serial_jtag.a esp-idf/driver/libdriver.a esp-idf/esp_phy/libesp_phy.a esp-idf/esp_vfs_console/libesp_vfs_console.a esp-idf/vfs/libvfs.a esp-idf/lwip/liblwip.a esp-idf/esp_netif/libesp_netif.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/esp_coex/libesp_coex.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/http_parser/libhttp_parser.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc/libesp_adc.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/3rdparty/everest/libeverest.a esp-idf/mbedtls/mbedtls/3rdparty/p256-m/libp256m.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libcore.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libespnow.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libmesh.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libnet80211.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libpp.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libsmartconfig.a /home/vgurav/esp/esp-idf/components/esp_wifi/lib/esp32s3/libwapi.a /home/vgurav/esp/esp-idf/components/xtensa/esp32s3/libxt_hal.a -u esp_app_desc -u esp_efuse_startup_include_func -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -u esp_system_include_startup_funcs -Wl,--wrap=longjmp -u __assert_func -Wl,--undefined=FreeRTOS_openocd_params -u app_main -lc -lm -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u newlib_include_init_funcs -u pthread_include_pthread_impl -u pthread_include_pthread_cond_var_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u pthread_include_pthread_semaphore_impl -Wl,--wrap=__register_frame_info_bases -Wl,--wrap=__register_frame_info -Wl,--wrap=__register_frame -Wl,--wrap=__register_frame_info_table_bases -Wl,--wrap=__register_frame_info_table -Wl,--wrap=__register_frame_table -Wl,--wrap=__deregister_frame_info_bases -Wl,--wrap=__deregister_frame_info -Wl,--wrap=_Unwind_Find_FDE -Wl,--wrap=_Unwind_GetGR -Wl,--wrap=_Unwind_GetCFA -Wl,--wrap=_Unwind_GetIP -Wl,--wrap=_Unwind_GetIPInfo -Wl,--wrap=_Unwind_GetRegionStart -Wl,--wrap=_Unwind_GetDataRelBase -Wl,--wrap=_Unwind_GetTextRelBase -Wl,--wrap=_Unwind_SetIP -Wl,--wrap=_Unwind_SetGR -Wl,--wrap=_Unwind_GetLanguageSpecificData -Wl,--wrap=_Unwind_FindEnclosingFunction -Wl,--wrap=_Unwind_Resume -Wl,--wrap=_Unwind_RaiseException -Wl,--wrap=_Unwind_DeleteException -Wl,--wrap=_Unwind_ForcedUnwind -Wl,--wrap=_Unwind_Resume_or_Rethrow -Wl,--wrap=_Unwind_Backtrace -Wl,--wrap=__cxa_call_unexpected -Wl,--wrap=__gxx_personality_v0 -Wl,--wrap=__cxa_throw -Wl,--wrap=__cxa_allocate_exception -u __cxa_guard_dummy -u __cxx_init_dummy -lstdc++ esp-idf/pthread/libpthread.a esp-idf/newlib/libnewlib.a -lgcc esp-idf/cxx/libcxx.a -u __cxx_fatal_exception -u esp_timer_init_include_func -u uart_vfs_include_dev_init -u usb_serial_jtag_vfs_include_dev_init -u usb_serial_jtag_connection_monitor_include -u include_esp_phy_override -lphy -lbtbb esp-idf/esp_phy/libesp_phy.a -lphy -lbtbb esp-idf/esp_phy/libesp_phy.a -lphy -lbtbb -u esp_vfs_include_console_register -u vfs_include_syscalls_impl && :
/home/vgurav/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld: esp-idf/main/libmain.a(espnow_touch_receive_simulate.c.obj):(.literal.app_send_hid_demo_touch+0x0): undefined reference to `tud_hid_n_report'
/home/vgurav/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld: esp-idf/main/libmain.a(espnow_touch_receive_simulate.c.obj): in function `tud_hid_report':
/home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/../managed_components/espressif__tinyusb/src/class/hid/hid_device.h:142:(.text.app_send_hid_demo_touch+0xc): undefined reference to `tud_hid_n_report'
collect2: error: ld returned 1 exit status
ninja failed with exit code 1, output of the command is in the /home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/log/idf_py_stderr_output_36547 and /home/vgurav/esp/esp-idf/examples/espidf_projects/touch_espnow/build/log/idf_py_stdout_output_36547
when i build my 2nd project then showing this error
Users browsing this forum: No registered users and 105 guests
