i2c_param_config(753): i2c clock choice is invalid, please check flag and frequency
Yolnit
Postby Yolnit » Fri Oct 04, 2024 7:41 am
Hello everybody,
I am working on a project where I need to do 2 things simultaniously. The first one is listening to a digital potentiometer (DP) in slave mode to get or set the wiper value. The other task is retrieving a raw data from a CAN (HX711) and corvert it into a weight value. I am using GPIO25 and 26 for the HX711 and >GPIO14 and 27 for the digital pot.
For now, both things are working well when separated, but here is the issue.
I am working with the hx711 library from https://github.com/UncleRus/esp-idf-lib ... 11/default
where the descriptor initialisation is has below
esp_err_t hx711_init(hx711_t *dev)
    CHECK_ARG(dev);
    gpio_config_t conf = {
        .pin_bit_mask = BIT(dev->dout),
        .mode = GPIO_MODE_INPUT,
        .pull_up_en = 0,
        .pull_down_en = 0,
        .intr_type = GPIO_INTR_DISABLE
    CHECK(gpio_config(&conf));
    conf.pin_bit_mask = BIT(dev->pd_sck);
    conf.mode = GPIO_MODE_OUTPUT;
    CHECK(hx711_power_down(dev, false));
    return hx711_set_gain(dev, dev->gain);
For the digital potentiometers, am using AD5245 IC https://www.mouser.fr/datasheet/2/609/A ... 601824.pdf
and I am actually using a library from https://github.com/UncleRus/esp-idf-lib ... 02/default
with this initialisation setup
esp_err_t ad5245_init_desc(i2c_dev_t *dev, uint8_t addr, i2c_port_t port, gpio_num_t sda_gpio, gpio_num_t scl_gpio)
    dev->port = port;
    dev->addr = addr;
    dev->cfg.sda_io_num = sda_gpio;
    dev->cfg.scl_io_num = scl_gpio;
#if HELPER_TARGET_IS_ESP32
    dev->cfg.master.clk_speed = I2C_FREQ_HZ;
#endif
    return i2c_dev_create_mutex(dev);
I have a IC_FREQ_HZ of 400kHz and I know I don't have the same for the hx711 device. Do I have to change the i2C frequency to match the IC with the smallest one?
The other issue is that when I try to run my software
static void call_global_configuration_functions_system(i2c_dev_t *dev){
    fflush(stdout);
    initialization_test_phase(NULL);    //Call the UART initialization communication function and the setting GPIO functions.
    spiffs_config();                //Initialization of the partitions
    //Initialization of I2C communication for the HX711s
    ESP_ERROR_CHECK(hx711_init(&hx711_dev));
    // Init i2cdev library
    ESP_ERROR_CHECK(i2cdev_init());
    first_use_potentiometer(&dev);
    // timer_creation(&timer_handler_wait_before_starting,false, &check_first_conf,3000);    //Don't send anything if timer isn't deleted
where
esp_err_t first_use_potentiometer(i2c_dev_t *dev){
    //Initialization of the other I2C bus
    ESP_ERROR_CHECK(ad5245_ready_to_use(&dev,AD5245_ADDR_0));
    // Read wiper position of driving motor
    ESP_ERROR_CHECK(ad5245_get_wiper_pos(&dev,pot_positions.driving_pot));
    // Write wiper position of driving motor
    ESP_ERROR_CHECK(ad5245_set_wiper_pos(&dev,ZERO_POS,true));
    //Free the buffer
    ESP_ERROR_CHECK(ad5245_free_desc(&dev));
I first call the hx711 initilization then the descriptor for the DP and set to 0 the wiper position. But I get this log :
I (27) boot: ESP-IDF v5.0.6-dirty 2nd stage bootloader
I (27) boot: compile time 15:11:35
I (27) boot: Multicore bootloader
I (31) boot: chip revision: v3.0
I (35) boot.esp32: SPI Speed      : 40MHz
I (39) boot.esp32: SPI Mode       : DIO
I (44) boot.esp32: SPI Flash Size : 4MB
I (49) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (57) boot: ## Label            Usage          Type ST Offset   Length
I (65) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (72) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (80) boot:  2 factory          factory app      00 00 00010000 00100000
I (87) boot:  3 storage          Unknown data     01 82 00110000 00100000
I (95) boot: End of partition table
I (99) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=0d934h ( 55604) map
I (127) esp_image: segment 1: paddr=0001d95c vaddr=3ffb0000 size=01fb4h (  8116) load
I (131) esp_image: segment 2: paddr=0001f918 vaddr=40080000 size=00700h (  1792) load
I (134) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=2df78h (188280) map
I (210) esp_image: segment 4: paddr=0004dfa0 vaddr=40080700 size=0dc90h ( 56464) load
I (240) boot: Loaded app from partition at offset 0x10000
I (240) boot: Disabling RNG early entropy source...
I (252) cpu_start: Multicore app
I (252) cpu_start: Pro cpu up.
I (252) cpu_start: Starting app cpu, entry point is 0x40081388
0x40081388: call_start_cpu1 at C:/Users/CorentinLEROY/esp/v5.0.6/esp-idf/components/esp_system/port/cpu_start.c:147
I (242) cpu_start: App cpu up.
I (270) cpu_start: Pro cpu start user code
I (270) cpu_start: cpu freq: 160000000 Hz
I (270) cpu_start: Application information:
I (275) cpu_start: Project name:     mybrouette
I (280) cpu_start: App version:      2462eed-dirty
I (286) cpu_start: Compile time:     Sep  4 2024 11:26:37
I (292) cpu_start: ELF file SHA256:  8122a54156b85591...
I (298) cpu_start: ESP-IDF:          v5.0.6-dirty
I (303) cpu_start: Min chip rev:     v0.0
I (308) cpu_start: Max chip rev:     v3.99
I (313) cpu_start: Chip rev:         v3.0
I (318) heap_init: Initializing. RAM available for dynamic allocation:
I (325) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (331) heap_init: At 3FFB2C20 len 0002D3E0 (180 KiB): DRAM
I (337) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (343) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (350) heap_init: At 4008E390 len 00011C70 (71 KiB): IRAM
I (357) spi_flash: detected chip: generic
I (361) spi_flash: flash io: dio
W (365) spi_flash: Detected size(16384k) larger than the size in the binary image header(4096k). Using the size in the binary image header.
I (379) app_start: Starting scheduler on CPU0
I (383) app_start: Starting scheduler on CPU1
I (383) main_task: Started on CPU0
I (393) main_task: Calling app_main()
I (393) gpio: GPIO[16]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (403) gpio: GPIO[17]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (413) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (543) gpio: GPIO[26]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (543) gpio: GPIO[25]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
Value of ADDR : 45
E (563) i2c: i2c_param_config(753): i2c clock choice is invalid, please check flag and frequency
ESP_ERROR_CHECK failed: esp_err_t 0x102 (ESP_ERR_INVALID_ARG) at 0x400d7572
0x400d7572: ad5245_ready_to_use at C:/Users/CorentinLEROY/Documents/Brouette/Code/mybrouette/components/ad5245/ad5245.c:128 (discriminator 1)
file: "./components/ad5245/ad5245.c" line 128
func: ad5245_ready_to_use
expression: ad5245_init(&dev)
abort() was called at PC 0x400874f3 on core 0
0x400874f3: _esp_error_check_failed at C:/Users/CorentinLEROY/esp/v5.0.6/esp-idf/components/esp_system/esp_err.c:47
So i decided to check the ad5245_init function that is here
esp_err_t ad5245_ready_to_use(i2c_dev_t *dev, uint8_t address){
    // Zero device descriptor
    memset(&dev, 0, sizeof(dev));
    // Initialize i2c device descriptor
    printf("Value of ADDR : %d\n\r", address);
    ESP_ERROR_CHECK(ad5245_init_desc(&dev, address,0, CONFIG_EXAMPLE_I2C_MASTER_SDA, CONFIG_EXAMPLE_I2C_MASTER_SCL));
    // Initialize potentiometer
    ESP_ERROR_CHECK(ad5245_init(&dev));
    return ESP_OK;
And I don't understand which frequency set the ad5245 descriptor configuration. I don't think the issue has something to deal with any king of flag, but I am not really sure.
I am using a ESP32E for this project. I can assure that separated, both devices work fine.
Thank by advance.
eriksl
Re: i2c_param_config(753): i2c clock choice is invalid, please check flag and frequency
Postby eriksl » Tue Oct 29, 2024 4:56 pm
The standard way to resolve this is, indeed, set the clock speed to the lowest capable attached device. 100 khz is a safe choice, all i2c devices support this. i2c is fully asynchronous so any clock speed you choose, between 100 khz (often (much) lower, even) and the highest speed of the slowest attached device will work.
On the esp32 (and variants) there's also an alternative approach. As there are two I2C controllers, you can attach both devices two separate controllers. If it doesn't work then....
Please note not all i2c devices are fully compliant. This may mean they can only work if no other devices are on the same bus.
Users browsing this forum: No registered users and 98 guests
