FCC BLE Conducted Test (Peak Power Test)
Naresh_NR
Postby Naresh_NR » Thu Oct 03, 2024 9:07 am
I am conducting a BLE transmission power test using an RF test toolkit and have encountered inconsistent results. I am using the ESP32S3-MINI-1 module, and the dBm values I obtained for low, mid, and high frequencies do not match the RF report provided by Espressif. Specifically, the power level decreases across frequencies:
Low frequency (2402 MHz): 7.8 dBm
Mid frequency (2440 MHz): 5.4 dBm
High frequency (2480 MHz): 4 dBm
The value at the low frequency is higher than those at the mid and high frequencies. Is this behavior normal or abnormal?
I have attached images showing how I set the values in the RF test toolkit, as well as the RF report from Espressif for reference.
Additionally, I would appreciate any guidance on properly setting up the RF test toolkit for a conducted test to measure BLE transmission power. Assistance in configuring the correct options for the test would be highly valued.
Thank you for your support.
RF Test Report (ESPRESSIF)
RF Test Report.png (100.46 KiB) Viewed 874 times
Test how I conducted
Test Config.png (106.96 KiB) Viewed 874 times
Users browsing this forum: Bing [Bot] and 62 guests
