1st stage loader bootloop
szwagier
Postby szwagier » Sun Sep 22, 2024 9:03 am
Hello.
I'm trying to run a 'hello world' project from IDF examples on a custom board. Chip is ESP32S3FH4R2 (integrated Flash and PSRAM).
Flashing runs smoothly:
esptool.py v4.7.0
Serial port /dev/ttyS0
Connecting....
Chip is ESP32-S3 (QFN56) (revision v0.2)
Features: WiFi, BLE, Embedded Flash 4MB (XMC), Embedded PSRAM 2MB (AP_3v3)
Crystal is 40MHz
MAC: 34:b7:da:5b:01:a8
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00006fff...
Flash will be erased from 0x00010000 to 0x00045fff...
Compressed 27872 bytes to 15748...
Writing at 0x00000000... (100 %)
Wrote 27872 bytes (15748 compressed) at 0x00000000 in 3.2 seconds (effective 68.6 kbit/s)...
Hash of data verified.
Compressed 219712 bytes to 111274...
Writing at 0x0004052e... (100 %)
Wrote 219712 bytes (111274 compressed) at 0x00010000 in 19.8 seconds (effective 88.8 kbit/s)...
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.1 seconds (effective 315.7 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Done
Veryfing too:
esptool.py -p /dev/ttyS0 verify_flash 0x0 build/bootloader/bootloader.bin
esptool.py v4.7.0
Connecting...
Detecting chip type... ESP32-S3
Crystal is 40MHz
Stub is already running. No upload is necessary.
Verifying 0x6ce0 (27872) bytes @ 0x00000000 in flash against build/bootloader/bootloader.bin...
-- verify OK (digest matched)
But after reset i see only this:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3810,len:0x24b0
load:0x403c9700,len:0x4
load:0x403c9704,len:0xf00
load:0x403cc700,len:0x38d0
entry 0x403c99f0
(3 sec delay)
Build:Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x403c99f0
(3 sec delay)
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c99f0
in endless loop.
I tried different flash mode settings, 40MHz flash speed, without success.
Also tried other examples, even precompiled .bin files, result is the same.
In bootloader settings in menuconfig i changed debug level, watchdog timeout, but all this has no effect.
Fuses:
espefuse.py -p /dev/ttyS0 summary
espefuse.py v4.7.0
Connecting...
=== Run "summary" command ===
EFUSE_NAME (Block) Description  = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
K_RTC_LDO (BLOCK1)                                 BLOCK1 K_RTC_LDO                                   = -20 R/W (0b1000101)
K_DIG_LDO (BLOCK1)                                 BLOCK1 K_DIG_LDO                                   = -28 R/W (0b1000111)
V_RTC_DBIAS20 (BLOCK1)                             BLOCK1 voltage of rtc dbias20                      = -28 R/W (0x87)
V_DIG_DBIAS20 (BLOCK1)                             BLOCK1 voltage of digital dbias20                  = -28 R/W (0x87)
DIG_DBIAS_HVT (BLOCK1)                             BLOCK1 digital dbias when hvt                      = -40 R/W (0b11010)
ADC2_CAL_VOL_ATTEN3 (BLOCK1)                       ADC2 calibration voltage at atten3                 = -4 R/W (0b100001)
TEMP_CALIB (BLOCK2)                                Temperature calibration data                       = 1.3 R/W (0b000001101)
OCODE (BLOCK2)                                     ADC OCode                                          = 87 R/W (0x57)
ADC1_INIT_CODE_ATTEN0 (BLOCK2)                     ADC1 init code at atten0                           = 436 R/W (0x6d)
ADC1_INIT_CODE_ATTEN1 (BLOCK2)                     ADC1 init code at atten1                           = 116 R/W (0b011101)
ADC1_INIT_CODE_ATTEN2 (BLOCK2)                     ADC1 init code at atten2                           = 96 R/W (0b011000)
ADC1_INIT_CODE_ATTEN3 (BLOCK2)                     ADC1 init code at atten3                           = 104 R/W (0b011010)
ADC2_INIT_CODE_ATTEN0 (BLOCK2)                     ADC2 init code at atten0                           = -180 R/W (0xad)
ADC2_INIT_CODE_ATTEN1 (BLOCK2)                     ADC2 init code at atten1                           = 124 R/W (0b011111)
ADC2_INIT_CODE_ATTEN2 (BLOCK2)                     ADC2 init code at atten2                           = 68 R/W (0b010001)
ADC2_INIT_CODE_ATTEN3 (BLOCK2)                     ADC2 init code at atten3                           = 88 R/W (0b010110)
ADC1_CAL_VOL_ATTEN0 (BLOCK2)                       ADC1 calibration voltage at atten0                 = 456 R/W (0x72)
ADC1_CAL_VOL_ATTEN1 (BLOCK2)                       ADC1 calibration voltage at atten1                 = 468 R/W (0x75)
ADC1_CAL_VOL_ATTEN2 (BLOCK2)                       ADC1 calibration voltage at atten2                 = 424 R/W (0x6a)
ADC1_CAL_VOL_ATTEN3 (BLOCK2)                       ADC1 calibration voltage at atten3                 = 476 R/W (0x77)
ADC2_CAL_VOL_ATTEN0 (BLOCK2)                       ADC2 calibration voltage at atten0                 = 0 R/W (0x80)
ADC2_CAL_VOL_ATTEN1 (BLOCK2)                       ADC2 calibration voltage at atten1                 = 248 R/W (0b0111110)
ADC2_CAL_VOL_ATTEN2 (BLOCK2)                       ADC2 calibration voltage at atten2                 = -8 R/W (0b1000010)
Config fuses:
WR_DIS (BLOCK0)                                    Disable programming of individual eFuses           = 0 R/W (0x00000000)
RD_DIS (BLOCK0)                                    Disable reading from BlOCK4-10                     = 0 R/W (0b0000000)
DIS_ICACHE (BLOCK0)                                Set this bit to disable Icache                     = False R/W (0b0)
DIS_DCACHE (BLOCK0)                                Set this bit to disable Dcache                     = False R/W (0b0)
DIS_TWAI (BLOCK0)                                  Set this bit to disable CAN function               = False R/W (0b0)
DIS_APP_CPU (BLOCK0)                               Disable app cpu                                    = False R/W (0b0)
DIS_DIRECT_BOOT (BLOCK0)                           Disable direct boot mode                           = False R/W (0b0)
UART_PRINT_CONTROL (BLOCK0)                        Set the default UART boot message output mode      = Enable R/W (0b00)
PIN_POWER_SELECTION (BLOCK0)                       Set default power supply for GPIO33-GPIO37; set wh = VDD3P3_CPU R/W (0b0)
                                                   en SPI flash is initialized
PSRAM_CAP (BLOCK1)                                 PSRAM capacity                                     = 2M R/W (0b10)
PSRAM_TEMP (BLOCK1)                                PSRAM temperature                                  = 105C R/W (0b01)
PSRAM_VENDOR (BLOCK1)                              PSRAM vendor                                       = AP_3v3 R/W (0b01)
BLOCK_USR_DATA (BLOCK3)                            User data
   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK_SYS_DATA2 (BLOCK10)                          System data part 2 (reserved)
Flash fuses:
FLASH_TPUW (BLOCK0)                                Configures flash waiting time after power-up; in u = 0 R/W (0x0)
                                                   nit of ms. If the value is less than 15; the waiti
                                                   ng time is the configurable value.  Otherwise; the
                                                    waiting time is twice the configurable value
FLASH_ECC_MODE (BLOCK0)                            Flash ECC mode in ROM                              = 16to18 byte R/W (0b0)
FLASH_TYPE (BLOCK0)                                SPI flash type                                     = 4 data lines R/W (0b0)
FLASH_PAGE_SIZE (BLOCK0)                           Set Flash page size                                = 0 R/W (0b00)
FLASH_ECC_EN (BLOCK0)                              Set 1 to enable ECC for flash boot                 = False R/W (0b0)
FORCE_SEND_RESUME (BLOCK0)                         Set this bit to force ROM code to send a resume co = False R/W (0b0)
                                                   mmand during SPI boot
FLASH_CAP (BLOCK1)                                 Flash capacity                                     = 4M R/W (0b010)
FLASH_TEMP (BLOCK1)                                Flash temperature                                  = 105C R/W (0b01)
FLASH_VENDOR (BLOCK1)                              Flash vendor                                       = XMC R/W (0b001)
Identity fuses:
DISABLE_WAFER_VERSION_MAJOR (BLOCK0)               Disables check of wafer version major              = False R/W (0b0)
DISABLE_BLK_VERSION_MAJOR (BLOCK0)                 Disables check of blk version major                = False R/W (0b0)
WAFER_VERSION_MINOR_LO (BLOCK1)                    WAFER_VERSION_MINOR least significant bits         = 2 R/W (0b010)
PKG_VERSION (BLOCK1)                               Package version                                    = 0 R/W (0b000)
BLK_VERSION_MINOR (BLOCK1)                         BLK_VERSION_MINOR                                  = 3 R/W (0b011)
WAFER_VERSION_MINOR_HI (BLOCK1)                    WAFER_VERSION_MINOR most significant bit           = False R/W (0b0)
WAFER_VERSION_MAJOR (BLOCK1)                       WAFER_VERSION_MAJOR                                = 0 R/W (0b00)
OPTIONAL_UNIQUE_ID (BLOCK2)                        Optional unique 128-bit ID
   = ce 02 4a 55 b6 60 48 41 ff ab a3 de d6 24 06 2a R/W
BLK_VERSION_MAJOR (BLOCK2)                         BLK_VERSION_MAJOR of BLOCK2                        = ADC calib V1 R/W (0b01)
WAFER_VERSION_MINOR (BLOCK0)                       calc WAFER VERSION MINOR = WAFER_VERSION_MINOR_HI  = 2 R/W (0x2)
                                                   << 3 + WAFER_VERSION_MINOR_LO (read only)
Jtag fuses:
SOFT_DIS_JTAG (BLOCK0)                             Set these bits to disable JTAG in the soft way (od = 0 R/W (0b000)
                                                   d number 1 means disable ). JTAG can be enabled in
                                                    HMAC module
DIS_PAD_JTAG (BLOCK0)                              Set this bit to disable JTAG in the hard way. JTAG = False R/W (0b0)
                                                    is disabled permanently
STRAP_JTAG_SEL (BLOCK0)                            Set this bit to enable selection between usb_to_jt = False R/W (0b0)
                                                   ag and pad_to_jtag through strapping gpio10 when b
                                                   oth reg_dis_usb_jtag and reg_dis_pad_jtag are equa
                                                   l to 0
Mac fuses:
MAC (BLOCK1)                                       MAC address
   = 34:b7:da:5b:01:a8 (OK) R/W
CUSTOM_MAC (BLOCK3)                                Custom MAC
   = 00:00:00:00:00:00 (OK) R/W
Security fuses:
DIS_DOWNLOAD_ICACHE (BLOCK0)                       Set this bit to disable Icache in download mode (b = False R/W (0b0)
                                                   oot_mode[3:0] is 0; 1; 2; 3; 6; 7)
DIS_DOWNLOAD_DCACHE (BLOCK0)                       Set this bit to disable Dcache in download mode (  = False R/W (0b0)
                                                   boot_mode[3:0] is 0; 1; 2; 3; 6; 7)
DIS_FORCE_DOWNLOAD (BLOCK0)                        Set this bit to disable the function that forces c = False R/W (0b0)
                                                   hip into download mode
DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0)               Set this bit to disable flash encryption when in d = False R/W (0b0)
                                                   ownload boot modes
SPI_BOOT_CRYPT_CNT (BLOCK0)                        Enables flash encryption when 1 or 3 bits are set  = Disable R/W (0b000)
                                                   and disabled otherwise
SECURE_BOOT_KEY_REVOKE0 (BLOCK0)                   Revoke 1st secure boot key                         = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE1 (BLOCK0)                   Revoke 2nd secure boot key                         = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE2 (BLOCK0)                   Revoke 3rd secure boot key                         = False R/W (0b0)
KEY_PURPOSE_0 (BLOCK0)                             Purpose of Key0                                    = USER R/W (0x0)
KEY_PURPOSE_1 (BLOCK0)                             Purpose of Key1                                    = USER R/W (0x0)
KEY_PURPOSE_2 (BLOCK0)                             Purpose of Key2                                    = USER R/W (0x0)
KEY_PURPOSE_3 (BLOCK0)                             Purpose of Key3                                    = USER R/W (0x0)
KEY_PURPOSE_4 (BLOCK0)                             Purpose of Key4                                    = USER R/W (0x0)
KEY_PURPOSE_5 (BLOCK0)                             Purpose of Key5                                    = USER R/W (0x0)
SECURE_BOOT_EN (BLOCK0)                            Set this bit to enable secure boot                 = False R/W (0b0)
SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0)             Set this bit to enable revoking aggressive secure  = False R/W (0b0)
                                                   boot
DIS_DOWNLOAD_MODE (BLOCK0)                         Set this bit to disable download mode (boot_mode[3 = False R/W (0b0)
                                                   :0] = 0; 1; 2; 3; 6; 7)
ENABLE_SECURITY_DOWNLOAD (BLOCK0)                  Set this bit to enable secure UART download mode   = False R/W (0b0)
SECURE_VERSION (BLOCK0)                            Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000)
                                                   ure)
BLOCK_KEY0 (BLOCK4)
  Purpose: USER
               Key0 or user data
BLOCK_KEY1 (BLOCK5)
  Purpose: USER
               Key1 or user data
BLOCK_KEY2 (BLOCK6)
  Purpose: USER
               Key2 or user data
BLOCK_KEY3 (BLOCK7)
  Purpose: USER
               Key3 or user data
BLOCK_KEY4 (BLOCK8)
  Purpose: USER
               Key4 or user data
BLOCK_KEY5 (BLOCK9)
  Purpose: USER
               Key5 or user data
Spi Pad fuses:
SPI_PAD_CONFIG_CLK (BLOCK1)                        SPI_PAD_configure CLK                              = 0 R/W (0b000000)
SPI_PAD_CONFIG_Q (BLOCK1)                          SPI_PAD_configure Q(D1)                            = 0 R/W (0b000000)
SPI_PAD_CONFIG_D (BLOCK1)                          SPI_PAD_configure D(D0)                            = 0 R/W (0b000000)
SPI_PAD_CONFIG_CS (BLOCK1)                         SPI_PAD_configure CS                               = 0 R/W (0b000000)
SPI_PAD_CONFIG_HD (BLOCK1)                         SPI_PAD_configure HD(D3)                           = 0 R/W (0b000000)
SPI_PAD_CONFIG_WP (BLOCK1)                         SPI_PAD_configure WP(D2)                           = 0 R/W (0b000000)
SPI_PAD_CONFIG_DQS (BLOCK1)                        SPI_PAD_configure DQS                              = 0 R/W (0b000000)
SPI_PAD_CONFIG_D4 (BLOCK1)                         SPI_PAD_configure D4                               = 0 R/W (0b000000)
SPI_PAD_CONFIG_D5 (BLOCK1)                         SPI_PAD_configure D5                               = 0 R/W (0b000000)
SPI_PAD_CONFIG_D6 (BLOCK1)                         SPI_PAD_configure D6                               = 0 R/W (0b000000)
SPI_PAD_CONFIG_D7 (BLOCK1)                         SPI_PAD_configure D7                               = 0 R/W (0b000000)
Usb fuses:
DIS_USB_OTG (BLOCK0)                               Set this bit to disable USB function               = False R/W (0b0)
USB_EXCHG_PINS (BLOCK0)                            Set this bit to exchange USB D+ and D- pins        = False R/W (0b0)
USB_EXT_PHY_ENABLE (BLOCK0)                        Set this bit to enable external PHY                = False R/W (0b0)
DIS_USB_JTAG (BLOCK0)                              Set this bit to disable function of usb switch to  = False R/W (0b0)
                                                   jtag in module of usb device
DIS_USB_SERIAL_JTAG (BLOCK0)                       Set this bit to disable usb device                 = False R/W (0b0)
USB_PHY_SEL (BLOCK0)                               This bit is used to switch internal PHY and extern
   = internal PHY is assigned to USB Device while external PHY is assigned to USB OTG R/W (0b0)
                                                   al PHY for USB OTG and USB Device
DIS_USB_SERIAL_JTAG_ROM_PRINT (BLOCK0)             USB printing                                       = Enable R/W (0b0)
DIS_USB_SERIAL_JTAG_DOWNLOAD_MODE (BLOCK0)         Set this bit to disable UART download mode through = False R/W (0b0)
                                                    USB
DIS_USB_OTG_DOWNLOAD_MODE (BLOCK0)                 Set this bit to disable download through USB-OTG   = False R/W (0b0)
Vdd fuses:
VDD_SPI_XPD (BLOCK0)                               SPI regulator power up signal                      = True R/W (0b1)
VDD_SPI_TIEH (BLOCK0)                              If VDD_SPI_FORCE is 1; determines VDD_SPI voltage
   = VDD_SPI connects to VDD3P3_RTC_IO R/W (0b1)
VDD_SPI_FORCE (BLOCK0)                             Set this bit and force to use the configuration of = True R/W (0b1)
                                                    eFuse to configure VDD_SPI
Wdt fuses:
WDT_DELAY_SEL (BLOCK0)                             RTC watchdog timeout threshold; in unit of slow cl = 40000 R/W (0b00)
                                                   ock cycle
Flash voltage (VDD_SPI) set to 3.3V by efuse.
Flash ID:
esptool.py -p /dev/ttyS0 flash_id
esptool.py v4.7.0
Connecting...
Crystal is 40MHz
Manufacturer: 20
Device: 4016
Detected flash size: 4MB
Flash type set in eFuse: quad (4 data lines)
Could this be a hardware problem?
sch.pdf
I added a 100n capacitor on SPI_VDD. Voltage on this pin is stable 3.28V.
Then I unsoldered the chip connected to GPIO33-37.
No result.
Now I'm out of ideas. Am I missing something obvious?
ESP_Sprite
Re: 1st stage loader bootloop
Postby ESP_Sprite » Mon Sep 23, 2024 12:32 am
Odd, I don't immediately see anything wrong with your setup. Do you have an ESP32S3 devboard you can flash the 'hello world' app into, to check if there's not something subtly wrong with your software environment?
szwagier
Postby szwagier » Tue Sep 24, 2024 6:25 am
Yes, i have two dev boards, the 'hello world' example (and any other) run on it without problems.
I flashed my board using a USB2UART converter, from Raspbery Pi serial port and directly from RS232 laptop port via MAX3232. Always same result.
In General Guidelines i found this:
The ground pad at the bottom of the chip should be connected to the ground plane through at least nine ground vias.
I have only 2 vias, could this be the cause of the problem?
ESP_Sprite
Postby ESP_Sprite » Tue Sep 24, 2024 8:44 am
I doubt that... fewer vias may affect RF performance, but shouldn't lead to boot issues like you have.
szwagier
Postby szwagier » Wed Sep 25, 2024 6:48 am
One more thing, the messages on the console are displayed correctly only if I select 38400 bps baudrade. On default 115200 i see only unrecognizable characters. Is this a normal behavior or suggests any problems with the clock?
ESP_Sprite
Postby ESP_Sprite » Wed Sep 25, 2024 7:55 am
That indeed sounds like the crystal somehow is not running at the correct frequency.
Users browsing this forum: Google [Bot] and 73 guests
