undefined reference to `port_clear_status(EVENT_GROUP_SELECT_T, unsigned long)'
Why does a simple project compile successfully by changing the source file A.cpp of custom component A to A.c, otherwise there will be a link error for undefined reference to "port_det_stat() - (in custom component B)"
- .cpp->.c successful,otherwais fail
- 1.png (43.13 KiB) Viewed 761 times
Re: undefined reference to `port_clear_status(EVENT_GROUP_SELECT_T, unsigned long)'
Is port_det_stat() declared as extern "C" when used from C++? (cf. https://embeddedartistry.com/blog/2017/ ... -extern-c/)
yes,the .h header file include "extren "C"MicroController wrote: ↑Fri Sep 06, 2024 3:39 amIs port_det_stat() declared as extern "C" when used from C++? (cf. https://embeddedartistry.com/blog/2017/ ... -extern-c/)
- #ifdef __cplusplus
extern "C" {
#endif #ifdef __cplusplus
#endif - 1.png (36.84 KiB) Viewed 676 times
Users browsing this forum: Corand and 66 guests
