Bluetooth Pairing with ESP32 Should Prompt for a Password Instead of Pairing Automatically
nakruf
Postby nakruf » Tue Sep 03, 2024 3:12 pm
I am working on an ESP32 Bluetooth project and I want the device to prompt for a password when connecting via Bluetooth. Currently, when I try to connect from a phone, it pairs automatically without asking for a password.
How can I configure the ESP32 so that it requests a password during the Bluetooth pairing process?
Thank you!
ESP-IDF v4.4.2
myCode
esp_err_t alb_bluetoothInit(const char* device_name)
    ESP_ERROR_CHECK(ret);
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(TAG, "initialize controller failed");
        return ret;
    ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT);
    if (ret) {
        ESP_LOGE(TAG, "enable controller failed");
        return ret;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(TAG, "initialize bluedroid failed");
        return ret;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(TAG, "enable bluedroid failed");
        return ret;
    esp_bt_dev_set_device_name(device_name);
    esp_spp_register_callback(spp_event_handler);
    esp_spp_init(ESP_SPP_MODE_CB);
    data_queue = xQueueCreate(DATA_QUEUE_SIZE, sizeof(char*));
    if (data_queue == NULL) {
        ESP_LOGE(TAG, "Failed to create data queue");
        return ESP_FAIL;
    data_len_queue = xQueueCreate(DATA_QUEUE_SIZE, sizeof(int));
    if (data_len_queue == NULL) {
        return ESP_FAIL;
    bt_register_event_handler(bt_event_callback);
    // GAP event handler'ı kaydet
    ret = esp_bt_gap_register_callback(gap_event_handler);
    if (ret != ESP_OK) {
        ESP_LOGE(TAG, "GAP callback registration failed: %s", esp_err_to_name(ret));
    // Bluetooth PIN kodu ayarı
    esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_FIXED;
    uint8_t pass[16] = {1,2,3,4};
    esp_bt_gap_set_pin(pin_type, BLUETOOTH_PIN_CODE_LEN, pas);
    esp_spp_start_srv(ESP_SPP_SEC_AUTHENTICATE, ESP_SPP_ROLE_MASTER, 0, "SPP_SERVER");
    printf("Bluetooth initialized successfully with name: %s\n", device_name);
    return ESP_OK;
Users browsing this forum: No registered users and 106 guests
