Hello everyone,
I have a general question regarding USB-OTG and Secure Boot V2 on esp32s3.
So according to espressif documentation: enabling the Secure Boot disables the USB-OTG Stack in the ROM.
So my question: will the USB-OTG Stack be disable temporary and only during the validation of the signature or will it be permanet disabled?
I mean, is any communication via USB-OTG after enabling SBV2 not possible anymore ? Or is it only not available only during the verification and validation process ?
So I did a simple example and tried to send a string "Hello" via USB and it has been sent. That means the USB-OTG is not disabled.
Screenshot:
Re: USB-OTG and Secure Boot V2
It will be disabled permanently. The issue is that the USB-OTG driver in ROM is a fairly large attack surface which we cannot patch, and we cannot guarantee there are no bugs in there.aygh4266 wrote: ↑Thu Aug 22, 2024 7:48 amSo my question: will the USB-OTG Stack be disable temporary and only during the validation of the signature or will it be permanet disabled?
Do note that this may impact less than you may think. USB-OTG can still be used in an application (as it doesn't use the ROM driver), and by default on the S3, the bootloader uses USB-serial-JTAG and not USB-OTG on the USB pins.
ESP_Sprite wrote: ↑Thu Aug 22, 2024 8:09 amIt will be disabled permanently. The issue is that the USB-OTG driver in ROM is a fairly large attack surface which we cannot patch, and we cannot guarantee there are no bugs in there.aygh4266 wrote: ↑Thu Aug 22, 2024 7:48 amSo my question: will the USB-OTG Stack be disable temporary and only during the validation of the signature or will it be permanet disabled?
First of all thank you very much for your quick reply. I tried to send a string "Hello" via USB using the tinyUSB stack and it worked. I attached a screenshot in my upper comment.
I also have read that by default, enabling Flash Encryption and/or Secure Boot will disable JTAG debugging. On first boot, the bootloader will burn an eFuse bit to permanently disable JTAG at the same time it enables the other features.
I am a little bit confused, how the USB-serial-JTAG can work after that ?
The JTAG bit will not work; you can try to connect to it but it won't see the CPU. The USB-to-serial bit will still function as a serial port.aygh4266 wrote: ↑Thu Aug 22, 2024 8:31 amI also have read that by default, enabling Flash Encryption and/or Secure Boot will disable JTAG debugging. On first boot, the bootloader will burn an eFuse bit to permanently disable JTAG at the same time it enables the other features.
Ok thanks.ESP_Sprite wrote: ↑Thu Aug 22, 2024 11:47 pm
But since the USB-OTG is disabled, I can communicate only with PC and send data over usb-serial.
Am I able to write data from esp32s3 to a smartphone or a usb-stick after enabling SBV2 ? I don't think I will be able to do this, since both of the devices must use USB-OTG and the esp32 must act as usb-host.
No, but you're not able to do that anyway without an app that does that for you as the bootloader does not do usb-host.
Users browsing this forum: Baidu [Spider], Google [Bot] and 82 guests
