Hello Guys,
I see Espressif IDE3.0.0 with ESP-IDF v5.2.2 has been online and available to download.
Now it is been quite fast to setup the devop chain tool. makes me exciting.
But I got error when I compile the LED Light example project(under ESP rainmaker).
Let me paste the error log:
CMake Error at D:/Espressif/frameworks/esp-idf-v5.2.2/tools/cmake/component.cmake:250 (message):
ERROR: Cannot process component requirements. Multiple candidates to
See also "C:/Users/linku/workspace/Led_light/build/CMakeFiles/CMakeOutput.log".
satisfy project requirements:
requirement: "qrcode" candidates: "espressif__qrcode, qrcode"
Anyone knows what happen? And what should I do?
CMake Error requirement: "qrcode" candidates: "espressif__qrcode, qrcode"
Re: CMake Error requirement: "qrcode" candidates: "espressif__qrcode, qrcode"
If you know which qrcode component you want to use (e.g., espressif__qrcode), you can explicitly specify it in your CMakeLists.txt file. This helps CMake to resolve the conflict.
Yes. I solved this problem by run idf.py and add qrcode dependency.
Thank you evry much.
Users browsing this forum: No registered users and 111 guests
