Can't even get started :(
palmiepaul
Postby palmiepaul » Fri Aug 16, 2024 5:42 am
Hey there. I've been given a board that identifies itself as a d1 mini. I understand that this means it is a Wemos ESP32 board. I've connected it to my Windows 11 PC and attempted to load a blink sketch from the Arduino IDE, but the following error message appears:
Sketch uses 268105 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20192 bytes (6%) of dynamic memory, leaving 307488 bytes for local variables. Maximum is 327680 bytes.
Failed uploading: no upload port provided
I've looked in the Tools menu, but Port option is grayed-out.
I've looked in the Select Other Boards And Ports dialog , but the Ports field shows No Ports Discovered.
I'm not even sure what the word Port means in this context.
Is there something else I should be doing (digging the garden, learning how to play hopscotch...)?
ESP_Sprite
Re: Can't even get started :(
Postby ESP_Sprite » Sat Aug 17, 2024 5:33 am
Are you sure your machine detects the devboard at all? (Also check if the USB cable you're using is not a charge-only cable.)
palmiepaul
Postby palmiepaul » Sat Aug 17, 2024 5:42 am
Hey there.
Thanks for your response.
The MCU is connected with a data cable; I use it to transfer photos from my camera.
I'm not sure the device is being detected by the PC. It doesn't show up in the File Explorer window This PC/Devices and Drives. Should it? How else would I check that?
ESP_Sprite
Postby ESP_Sprite » Sat Aug 17, 2024 6:18 am
It should show up as a COM-port (serial port) in the Windows device manager.
MicroController
Postby MicroController » Sat Aug 17, 2024 7:11 pm
The Wemos D1 mini is built around an ESP8266, which is not the same as the ESP32. You may have to (also) select a different board in the Arduino IDE.
Users browsing this forum: No registered users and 97 guests
