so I have enabled the Secure Boot sucessfully, generated the private signing key using OpenSSL. So after running the command , it stays in the bootloader. So I ran the command idf.py monitor, but it gives me an invalid header.
First and second output
[esptool.py -p COM4 -b 1152000 --before default_reset --after no_reset --chip esp32s3 write_flash --flash_mode dio --flash_size detect --flash_freq 80m 0x10000 build/partition_table/partition-table.bin
0x20000 build/app-template.bin
esptool.py v4.7.0
Serial port COM4
Connecting....
Chip is ESP32-S3 (QFN56) (revision v0.1)
Features: WiFi, BLE, Embedded Flash 8MB (GD)
Crystal is 40MHz
MAC: f4:12:fa:87:c4:d8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 1152000
Changed.
Configuring flash size...
Auto-detected Flash size: 8MB
Flash will be erased from 0x00010000 to 0x00010fff...
Flash will be erased from 0x00020000 to 0x000b0fff...
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00010000 in 0.0 seconds (effective 588.2 kbit/s)...
Hash of data verified.
Compressed 593920 bytes to 334892...
Wrote 593920 bytes (334892 compressed) at 0x00020000 in 4.7 seconds (effective 1010.6 kbit/s)...
Leaving...
Staying in bootloader/]
Second output:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
invalid header: 0x020150aa
invalid header: 0x020150aa]]
