Note: iam using example code (D:\ESP_ADF\esp-adf\examples\player\pipeline_a2dp_source_stream)
1)audio_element_set_uri(fatfs_stream_reader, "/sdcard/test.mp3"); // i had set the same path still no luck
2)discovery and connection is absolutely fine when comes to transmission itself open the file is an error
3)File is also exsist in the sdcard
code:
f (fatfs->type == AUDIO_STREAM_READER) {
fatfs->file = open(path, O_RDONLY);//this value is returning -1
4)mount path is also crct and sd card init also fyn
Unable to open the sd card mp3 file while transmitting audio data to connected device through bluetooth a2dp profile
- sd card path
- sd_pic.PNG (26.29 KiB) Viewed 966 times
- output log file openeing error
- error_Pic.PNG (43.05 KiB) Viewed 966 times
Re: Unable to open the sd card mp3 file while transmitting audio data to connected device through bluetooth a2dp profile
Expecting the reply from admin??
Users browsing this forum: No registered users and 58 guests
