Hi everybody,
some time ago i used this workaround, because my ESP32 became inresponsive in the network after some time:
extern "C" {
extern char *netif_list;
uint8_t etharp_request(char *, char *); // required for forceArp to work
void forceARP() {
char *netif = netif_list;
while (netif)
etharp_request((netif), (netif + 4));
netif = *((char **) netif);
It is called every second and worked great. Now I try to compile it with another computer with a newer version of the Arduino IDE and the ESP32 core. It compiles, but when the forceARP() function is called I get the following error:
assertion "netif->hwaddr_len must be the same as ETH_HWADDR_LEN for etharp!" failed: file "/Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/lwip/netif/etharp.c", line 1306, function: etharp_raw
abort() was called at PC 0x400dac57 on core 1
Any ideas?
Thanks!
"etharp_request" workaround does not work anymore
Re: "etharp_request" workaround does not work anymore
I know that is very VERY old topic, but it looks that is till applicable.
I got around the issue with the following code:
extern "C" {
#include "lwip/netif.h"
void forceARP()
netif *netif = netif_list;
while (netif)
if(netif->hwaddr_len == 6)
etharp_request((char*)(netif), (char*)netif_ip4_addr(netif));
netif = netif->next;
// The loop function is called in an endless loop
void loop()
static uint32_t timer = millis();
if((millis()-timer) >100)
timer = millis();
forceARP();
Users browsing this forum: No registered users and 43 guests
