Hello, recently I downloaded the basic routine of the official Ethernet.
I set the Ethernet in the configuration as the internal Ethernet controller LAN87XX.
On the hardware, we use ESP32 as the main control MCU, LAN8720A chip to control Ethernet, and FC-13ENL as the network port. The software program on another ESP32 chip can be confirmed to run normally, but we encounter the following problems on this ESP32: there are problems with lan87xx: lan87xx_init(299): wrong chip OUI and esp_eth: esp_eth_driver_install(229): init phy failed.
How can we solve this problem?
Error when using Ethernet with ESP32
Re: Error when using Ethernet with ESP32
Do you use some devboard or your custom board?
I also encountered this problem. Have you resolved it?
Do you use some devboard or your custom board? Is PHY address correctly set?
Users browsing this forum: No registered users and 93 guests
