I'm using the ESP32-S3-VROOM-1 module in my design.
I would like to use the built-in USB/JTAG interface (via GPIO19 and GPIO20) as a USB CDC serial port (for connecting to a host PC) and as a JTAG debug interface.
I know that there is a driver that allows me to use this interface as a UART. My question is: How should I configure my software and fuses to allow both serial interface AND JTAG debug from the same USB connection?
I also have an ESP32-S3-DevKitC-1 so I can test my code.
Thanks,
Yair
Using the built-in USB/JTAG interface for my design
Re: Using the built-in USB/JTAG interface for my design
That works. The hardware provides two different endpoints on the USB interface. One is for JTAG and the other endpoint is either virtual serial CDC/ADM (I can't recall which it is, but "serial port") or whatever you want it to be. So if you create ESP32 software to be an endpoint for a mass storage device or a printer or a keyboard or whatever, it can be those, too.
There are tons of examples on GitHub.
You don't have to do anything: by default the USB-JTAG-serial port is enabled and provides both serial and JTAG functionality at the same time. (Although if you want to use fgets() and friends you may need to make it the primary console in menuconfig).
Users browsing this forum: Bing [Bot] and 136 guests
