esp32s3-lcd-ev-borad例程,扫描不到AP节点
q81679
Postby q81679 » Tue Jul 09, 2024 2:19 am
使用的例程是86box smart panel,在烧录开发板后,发现无法扫描到AP节点?原因是什么?
idf版本:5.2.1
  1. I (3701) wifi:wifi driver task: 3fccad68, prio:23, stack:6656, core=0
  2. I (3719) wifi:wifi firmware version: a9f5b59
  3. I (3720) wifi:wifi certification version: v7.0
  4. I (3720) wifi:config NVS flash: enabled
  5. I (3720) wifi:config nano formating: disabled
  6. I (3725) wifi:Init data frame dynamic rx buffer num: 32
  7. I (3730) wifi:Init static rx mgmt buffer num: 5
  8. I (3734) wifi:Init management short buffer num: 32
  9. I (3738) wifi:Init static tx buffer num: 4
  10. I (3742) wifi:Init tx cache buffer num: 16
  11. I (3752) wifi:Init static tx FG buffer num: 2
  12. I (3756) wifi:Init static rx buffer size: 1600
  13. I (3761) wifi:Init static rx buffer num: 10
  14. I (3764) wifi:Init dynamic rx buffer num: 32
  15. I (3769) wifi_init: rx ba win: 6
  16. I (3772) wifi_init: tcpip mbox: 32
  17. I (3773) ui_WiFi.c: update wifi list
  18. I (3776) wifi_init: udp mbox: 6
  19. I (3784) wifi_init: tcp mbox: 6
  20. I (3788) wifi_init: tcp tx win: 5760
  21. I (3792) wifi_init: tcp rx win: 5760
  22. I (3797) wifi_init: tcp mss: 1440
  23. I (3801) wifi_init: WiFi/LWIP prefer SPIRAM
  24. I (3806) wifi_init: WiFi IRAM OP enabled
  25. I (3810) wifi_init: WiFi RX IRAM OP enabled
  26. I (3826) phy_init: phy_version 640,cd64a1a,Jan 24 2024,17:28:12
  27. I (3865) wifi:mode : sta (7c:df:a1:e1:c7:08)
  28. I (3865) wifi:enable tsf
  29. I (3867) wifi station: start connect to the AP
  30. I (3867) wifi station: wifi_init_sta finished.hfwl:4, hfwl12345678:12
  31.
  32. I (17559) ui_WiFi.c: refresh
  33. I (17947) wifi station: NET_EVENT_SCAN
  34. I (17947) wifi station: Max AP number ap_info can hold = 20
  35. I (20378) wifi station: Total APs scanned = 0, ret:0
  36. I (21378) wifi station: failed return
  37. I (23379) ui_WiFi.c: update wifi list
Users browsing this forum: No registered users and 70 guests
