Using the Second USB-C Port on ESP32-S3 to Read Data via VCP Protocol
harith
Postby harith » Mon Jul 08, 2024 2:11 pm
Hi everyone,
I have an ESP32-S3 development board that comes with two USB-C ports. I'm working on a project where I need to read data from a Dracal RTD300 sensor connected via a USB controller. The sensor sends data using the Virtual COM Port (VCP) protocol.
My question is: Is it possible to use the second USB-C port on the ESP32-S3 to read data sent via the VCP protocol? If so, could you provide some guidance or example code on how to set this up using TinyUSB or any other relevant library?
I saw that there is a lib for arduino : Adafruit_TinyUSB_Arduino
Here are some details about my setup:
Sensor: Dracal RTD300 (https://www.dracal.com/en/product/rtd300/)
Board: ESP32-S3 with dual USB-C ports
Requirement: Read data from the sensor using the VCP protocol via the second USB-C port
Any advice or examples would be greatly appreciated!
Thanks in advance for your help!
Users browsing this forum: No registered users and 77 guests
