ESP-IDF extension for Visual Studio Code 1.8.0
Features and enhancements
Add button to enable custom partition when calling Partition table editor
Add ESP-IDF version switcher
Translation using l10n vscode api, remove gulp files
Add Eclipse CDT Debug Adapter and update debugging documentation
Add Chip Id in port selection
Add idf.py reconfigure task as extension command
Add white spaces support for IDF_PATH and extension tasks
Add Hints viewers bar and code editor highlight
Add docs espressif files and workflow
Bug Fixes
Avoid saveDefSdkconfig in all menu items
Add clarity to flash placeholder text
Fix output channel interrupt
Fix github tags to retrieve up to 100 tags
Fix and update devcontainer json mount and python setting
Add no ports validation
Update blink example reference in docs
Consistent ESP Component Registry URL
Re: ESP-IDF extension for Visual Studio Code 1.8.0
Thanks for the continued development of that. I think it's the best "middle ground abstraction" IDE.
Users browsing this forum: No registered users and 15 guests
