Esp32S3 : VFS Component. How to determine Freemem and Used mem on a FileSystem ?
ThomasESP32
Postby ThomasESP32 » Thu Jun 27, 2024 12:43 pm
Good afternoon,
I am working on a firmware running on an Esp32S3.
I have 3 partitions that are "referenced" using Virtual FileSystem component and a FileSystem is mounted on each partition.
Using VFS, is there a way to determine the amount of free memory (In bytes) and the amount of used memory (In bytes)
available on each FileSystem ?
Thank you for your help,
Best regards,
Thomas TRUILHE
ESP_Sprite
Re: Esp32S3 : VFS Component. How to determine Freemem and Used mem on a FileSystem ?
Postby ESP_Sprite » Fri Jun 28, 2024 1:28 am
For reference, on other Posix OSses, you'd do it by running stat() on the directory where the filesystem is mounted. Potentially newlib has the same convention.
Users browsing this forum: No registered users and 88 guests
