sdkconfig for multiple projects with common code components
jesper
Postby jesper » Thu Jun 27, 2024 7:37 am
I have roughly this setup.
[size=85]- common_code/
        - component1/
                - include/ - component1.h
                - Kconfig
                - src1.c
        - component2/
                - include/ - component2.h
                - Kconfig
                - src2.c
- Project_1/
        - build/
        - main/
            - src3.c
            - src4.c
            - CMakeLists.txt
        - CMakeLists.txt
        - sdkconfig
- Project_2/
        - build/
        - main/
            - src5.c
            - src6.c
            - CMakeLists.txt
        - CMakeLists.txt
        - sdkconfig[/size]
The common_code folder contains various hardware drivers that are used by both Project_1 and Project_2.
However, the GPIO configurations and some other parameters are different.
The Kconfig in each component folder contains a “default” configuration.
This is an example of the Kconfig for the accelerometer component.
[size=85]menu "Accelerometer Component Configuration"
    menu "Accelerometer Configuration"
        config ACCELEROMETER_I2C_ADDRESS
            int "Accelerometer I2C Addess"
            default 24
            range 0 255
            help
                I2C Address of accelerometer.
        config ACCELEROMETER_INTERRUPT_GPIO
            int "Accelerometer Interrupt Pin Number"
            default 4
            range 0 31
            help
                Pin number of accelerometer interrupt GPIO.
    endmenu
endmenu[/size]
I had hoped to be able to open the sdkconfig in each project in the sdkconfig editor (Espressif IDE) and configure the specific settings.
However, when I build the project, the sdkconfig settings are overwritten by the Kconfig settings.
I could, of course, have a sdkconfig.default or so in each Project folder, but that would require this to be created/copied manually and
if a new setting is added to a component, all projects needs to have their sdkconfig.default files updated manually.
As it is now, it looks smooth, the component setting show up in sdkconfig.
But sadly, it doesn’t work, as I cannot change the config, per project.
Any ideas how to accomplish this?
Did I miss something?
MagicMicros Co., Ltd. - Rayong, Thailand
Electronics design, PCB layout & programming.
ESP_Sprite
Re: sdkconfig for multiple projects with common code components
Postby ESP_Sprite » Thu Jun 27, 2024 8:37 am
I think some of the ESP-IDF examples or testcases do this; they use their own KConfig files to force certain values in the general menuconfig. You may want to browse through that for inspiration.
jesper
Postby jesper » Thu Jun 27, 2024 11:20 am
Ignore post, stupid mistake, I couldn't see the forest for the trees.
Problem solved, it DOES work as planned.
Users browsing this forum: gamename and 65 guests
