esp32s3使用vs+idf配置目标芯片和编译ESP IoT Solution报错
Moderator: ESP_Bob
yunfusheng
Postby yunfusheng » Tue Jun 25, 2024 6:24 am
请问,我在esp32s3使用vs+idf配置目标芯片ESP IoT Solution报下面的错误,我也有选择我所用USB下的cmake文件
我的idf版本是5.2.1,ESP IoT Solution版本是最新的,idf自带的例程可以正常编译烧录
[Error: non zero exit code 2
WARNING: Python interpreter "D:\work\ESP32\Espressif\python_env\idf5.2_py3.11_env\Scripts\python.exe" used to start idf.py is not from installed venv "D:/work/ESP32/Espressif/python_env/idf5.2_py3.11_env"
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Executing action: set-target
Set Target to: esp32s3, new sdkconfig will be created.
Running cmake in directory D:\work\ESP32\esp-project\esp-iot-solution-master\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:\work\ESP32\Espressif\python_env\idf5.2_py3.11_env\Scripts\python.exe -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=0 D:\work\ESP32\esp-project\esp-iot-solution-master"...
-- Found Git: D:/work/ESP32/Espressif/tools/idf-git/2.43.0/cmd/git.exe (found version "2.43.0.windows.1")
-- Component directory D:/work/ESP32/esp-project/esp-iot-solution-master/components/audio does not contain a CMakeLists.txt file. No component will be added
-- Component directory D:/work/ESP32/esp-project/esp-iot-solution-master/components/bluetooth does not contain a CMakeLists.txt file. No component will be added
在我吧usb/divice/usb dongle下cmake移动到根目录下不再报这个错误但是编译时头文件不识别了
请问我是否有漏掉那些步骤或者那些步骤不对?
Users browsing this forum: No registered users and 14 guests
