Hello All,
Is it possible to interface 64GB SD card with ESP32-C6-WROOM?
As I do not see any documentation of whether ESP32-C6 has ExFAT support.
Please do confirm.
ESP32-C6 SD card support for 64GB
Re: ESP32-C6 SD card support for 64GB
Hello, Yes, you can use a 64GB SD card with the ESP32-C6. You can use it on the SPI interface. Please refer to this example: https://github.com/espressif/esp-idf/tr ... card/sdspi. Using exFAT requires purchasing a license from Microsoft, and we do not support exFAT in IDF. You can use the FAT32 file system instead.
64GB will work, and exFAT should too.
Not sure about the licensing requirements for exFAT, since apparently Microsoft ♥ Linux.
Users browsing this forum: MicroController and 123 guests
