Brain dead Wemos Lolin32
Rrobinet
Postby Rrobinet » Mon Dec 25, 2017 8:26 am
While busy to implement a new library, and after downloading this version to my WeMos Lolin 32 (using Arduino IDE), I had the following issue:
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:812
load:0x40078000,len:0
load:0x40078000,len:11392
entry 0x40078a9c
Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
. Exception was unhandled.
Register dump:
PC      : 0x400013f9  PS      : 0x00060530  A0      : 0x800d2036  A1      : 0x3ffcb590
A2      : 0x3ffc51a8  A3      : 0x00000000  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00000000  A9      : 0x3ffcb510
A10     : 0x3ffc51a8  A11     : 0x3ffc6000  A12     : 0x00000000  A13     : 0x0000ff00
A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x00000014  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x400013f9  LEND    : 0x4000140d  LCOUNT  : 0xffffffff
Backtrace: 0x400013f9:0x3ffcb590 0x400d2033:0x3ffcb5a0 0x400d2086:0x3ffcb5c0 0x400d10b4:0x3ffcb5e0 0x400f050d:0x3ffcb620
Of course I am not able to reload a new sketch, the loader esp 2.1 give me the following error.
esptool.py v2.1
Connecting........_____....._____....._____....._____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch
I looks that the boot loader can't be accessed anymore due to the constant processor reboot.
Is it a way to overcome this situation?
Thanks in advance
Robert
Rrobinet
Re: Brain dead Wemos Lolin32
Postby Rrobinet » Mon Dec 25, 2017 8:32 am
Extra info; after attempt to download a sketch; the following message is displayed:
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
....... U............ U............ U............ U............ U............ U............ U............ U............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. .....ets Jun  8 2016 00:22:57
...... UU........... UU........... UU........... UU........... UU........... UU........... UU........... UU............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. ............. .....ets Jun  8 2016 00:22:57
chegewara
Postby chegewara » Mon Dec 25, 2017 9:06 am
If you have hardware buttons reset and boot, try to enable download mode and then upload sketch from arduino.
Download mode:
- press boot, dont release it
- press and release reset
- release boot
But before you do that, open serial monitor to be sure esp32 is in download more. Then close serial monitor and upload sketch
Rrobinet
Postby Rrobinet » Tue Dec 26, 2017 8:32 am
Thanks chegewara for your help.
In fact the Wemos Lolin has no reset button, so based on your infos I have found, this article:
https://github.com/espressif/esptool/wi ... e-Selection
So I did power my Wemos with GPIO0 strapped to the ground, the after removing the strap I was able to reload a sketch.
Robert
Users browsing this forum: No registered users and 25 guests
