SD-Card --> Filesystem gets corrupted aftr random time
esp32newie
Postby esp32newie » Sat Jun 08, 2024 4:28 pm
i use an ESP32 with a 3.3Volt SD-Card-Modul for data logging of my power meter.
One of my main functions is this, which refreshes a day-sum-file.
File is saved to SD card.
My curent problem is, that after random time (sometimes weeks, sometimes month) the file system seems to get destroyed/corrupted. Files on SD Card then all have strange names like "!")$/§)" and are not readable anymore.
Here is the current code (please stay friendly... i am a beginner :-)
// Struct at the moment has just one value
// Will be more in final script, so don't wonder why i use a struct here please ;-)
struct data_s {
  double kwh;
//Parameters
//filename_tmp : e.g. "2024-06-08.bin"
//measuring_kwh: e.g. "0.45"
void refresh_daysum (const char* filename_tmp, double measuring_kwh) {
  struct data_s sum;
  File sumFile;
  if (SD.exists(filename_tmp)) {
    // Read out current value
    sumFile= SD.open(filename_tmp, FILE_READ);
    while (sumFile.available()) {
      sumFile.read((uint8_t *)&summe, sizeof(summe));
    sumFile.close();
    // add new measuring to current value
    sum.kwh = sum.kwh + measuring_kwh;
    // First measuring of the day
    sum.kwh = measuring_kwh;
  // Question is, if this part of the code is bad.
  // Is it bad to delete the file and create it anew every time?
  // Would it be better for SD-life to keep the file and just refresh the value?
  SD.remove(filename_tmp);
  sumFile= SD.open(filename_tmp, FILE_WRITE);
  sumFile.write((uint8_t *)&summe, sizeof(summe));
  sumFile.close();
Is this function maybe cause of the SD-Card defect?
Another question:
Is it better / required to check if SD-Card-Reader is ready with SD.begin(pinNum) prior to saving data each time.
Or is it ok to just call SD.begin() in void Setup()
Thank you for your support.
Users browsing this forum: Google [Bot] and 71 guests
