Re: [SOLVED]Issues in Non-Blocking/Interrupt Based UART
Dakshk
Postby Dakshk » Fri Jun 07, 2024 4:46 am
Error can be solved by following method though I do not recommend that, but it can implement interrupt based UART and you can have functioning code.
So, our approach was to use the function
isr_register
and
isr_free
which were removed in newer version of IDF, for that you have to make few changes in UART.c and UART.h:
1. copy both of above-mentioned codes from older version of SDK found from github and paste them into your files (UART.c and UART.h).
2. in
uart_driver_install
function find
 uart_int_alloc
function and replace it with
uart_isr_register
(for this you can directly compare from both SDKs
uart_driver_install
function).
Feel free to ask question.
Users browsing this forum: No registered users and 72 guests
