I used ESP32 module and using Mqtt AT Command i Communicate with ESP 32,
I want to update the mqtt Certificate on ESP32 using AT Command so how i can do this?
or using AT Command can we update the mqtt Certificate?
or we used another method to update the mqtt Certificate on ESP32?
Replace or add all three MQTT Certificate on ESP32 using AT Command
Re: Replace or add all three MQTT Certificate on ESP32 using AT Command
Hello every one,
Please give me advice using AT Command how i can update or Replace MQTT Certificate
