secure boot and flash encryption error when enabling together
chandramauli
Postby chandramauli » Tue May 21, 2024 6:55 am
I am trying to enable secure boot and flash encryption together in ESP32-S3 with below macros. In this configuration development mode is enabled for both.
CONFIG_SECURE_SIGNED_ON_BOOT=y
CONFIG_SECURE_SIGNED_ON_UPDATE=y
CONFIG_SECURE_SIGNED_APPS=y
CONFIG_SECURE_BOOT_V2_RSA_SUPPORTED=y
CONFIG_SECURE_BOOT_V2_PREFERRED=y
CONFIG_SECURE_BOOT_V2_RSA_ENABLED=y
CONFIG_SECURE_SIGNED_APPS_RSA_SCHEME=y
CONFIG_SECURE_BOOT=y
CONFIG_SECURE_BOOT_V2_ENABLED=y
CONFIG_SECURE_BOOT_BUILD_SIGNED_BINARIES=y
CONFIG_SECURE_BOOT_SIGNING_KEY="secure_boot_signing_key.pem"
CONFIG_SECURE_BOOT_ENABLE_AGGRESSIVE_KEY_REVOKE=n
CONFIG_SECURE_BOOT_INSECURE=y
CONFIG_SECURE_ROM_DL_MODE_ENABLED=y
CONFIG_SECURE_ENABLE_SECURE_ROM_DL_MODE=y
CONFIG_ESPTOOLPY_NO_STUB=y
CONFIG_SECURE_FLASH_ENC_ENABLED=y
CONFIG_SECURE_FLASH_ENCRYPTION_AES128=y
CONFIG_SECURE_FLASH_ENCRYPTION_MODE_DEVELOPMENT=y
CONFIG_SECURE_FLASH_HAS_WRITE_PROTECTION_CACHE=y
CONFIG_SECURE_FLASH_UART_BOOTLOADER_ALLOW_ENC=y
CONFIG_SECURE_FLASH_SKIP_WRITE_PROTECTION_CACHE=y
CONFIG_SECURE_FLASH_CHECK_ENC_EN_IN_APP=y
CONFIG_SECURE_INSECURE_ALLOW_DL_MODE=y
CONFIG_FLASH_ENCRYPTION_ENABLED=y
CONFIG_FLASH_ENCRYPTION_INSECURE=y
CONFIG_FLASH_ENCRYPTION_UART_BOOTLOADER_ALLOW_ENCRYPT=y
CONFIG_NVS_ENCRYPTION=n
Secure boot is successfully enabled in the device but not able to enable flash encryption. I am not able to read efuse values as it shows "A fatal error occurred: Secure Download Mode is enabled. The tool can not read eFuses."
I have flashed bootloader,partition table and application binaries with esptool.py tool at specific location.
Can someone help to follow exact steps to avoid device breaking up? I am clueless for the new implementation.
Regards,
Chandramauli
liaifat85
Re: secure boot and flash encryption error when enabling together
Postby liaifat85 » Tue May 21, 2024 6:20 pm
Did you check here for answers?
https://esp32.com/viewtopic.php?f=13&t=33828
chandramauli
Postby chandramauli » Wed May 29, 2024 11:51 am
Hi
Yes, I had a chance to visit this but didn't find any useful information for my case. can anyone help me with exact steps to be followed to enable flash encryption and secure boot together in ESP32-S3?
Regards,
Chandramauli
Users browsing this forum: Bing [Bot] and 85 guests
