Error while trying to update the firmware via OTA
Heet_Shukla
Postby Heet_Shukla » Mon May 20, 2024 12:33 pm
Currently I'm wroking on ESP32 wroom 16mb.
I'm fetching firmware file from Web Server for OTA using GSM Module Cavli C16Qs. Cavli C16Qs is Connected with ESP32 via ESP Serial1.
I Configure HTTP Connection with cavli C16Qs to server using AT COMMAND. I also able to download file from server. Esp32 is getting file from ATSerial(ESP32 Serial1). My Firmware file size is 250KB. So i need to append that file. I tried but File is corrupted.
The size of the file being appended is the same as my BIN file. But when I am read that file, the data in that file is corrupted.
If any normal words are appended or used in read, they are being appended correctly. But when I try to append my firmware file it is not appending correctly. it is corrupted.
I'm use Partition Scheme: 16MB flash (3MB APP/9.9MB FATFS) for Append file.
I'm append file using FFat file system, And 16mb file partition.
so basically Issue why I'm not able to append data of file properly?
  1. #include "FS.h"
  2. #include "FFat.h"
  3. #include <freertos/FreeRTOS.h>
  4. #include <freertos/task.h>
  5. #include <freertos/queue.h>
  6.
  7. #include "soc/timer_group_struct.h"
  8. #include "soc/timer_group_reg.h"
  9.
  10. #define BUFFER_SIZE 256
  11. #define QUEUE_SIZE 300
  12.
  13. unsigned long lastSerial1Time = 0;
  14. QueueHandle_t QueueHandle;
  15.
  16. File FF;
  17.
  18. struct DataPacket {
  19.   uint8_t data[BUFFER_SIZE];
  20.   size_t bytesRead;
  21. };
  22.
  23. bool packet_start = false;
  24. String currentSTR = "";
  25. #define FORMAT_FFAT true
  26.
  27. void dataprocesa(void *pvParameters);
  28. void TaskReadFromSerial(void *pvParameters);
  29. void checkSPIFFSFreeSpace();
  30. void listDir(fs::FS &fs, const char *dirname, uint8_t levels);
  31. void readFile(fs::FS &fs, const char *path);
  32. void feedTheDog();
  33.
  34. void checkSPIFFSFreeSpace() {
  35.   size_t totalBytes = FFat.totalBytes();
  36.   size_t usedBytes = FFat.usedBytes();
  37.   size_t freeBytes = totalBytes - usedBytes;
  38.
  39.   Serial.print("Total space: ");
  40.   Serial.print(totalBytes);
  41.   Serial.println(" bytes");
  42.
  43.   Serial.print("Used space: ");
  44.   Serial.print(usedBytes);
  45.   Serial.println(" bytes");
  46.
  47.   Serial.print("Free space: ");
  48.   Serial.print(freeBytes);
  49.   Serial.println(" bytes");
  50. }
  51.
  52. void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
  53.   Serial.printf("Listing directory: %s\r\n", dirname);
  54.
  55.   File root = fs.open(dirname);
  56.   if (!root) {
  57.     Serial.println("- failed to open directory");
  58.     return;
  59.   }
  60.   if (!root.isDirectory()) {
  61.     Serial.println(" - not a directory");
  62.     return;
  63.   }
  64.
  65.   File file = root.openNextFile();
  66.   while (file) {
  67.     if (file.isDirectory()) {
  68.       Serial.print("  DIR : ");
  69.       Serial.println(file.name());
  70.       if (levels) {
  71.         listDir(fs, file.path(), levels - 1);
  72.       }
  73.     } else {
  74.       Serial.print("  FILE: ");
  75.       Serial.print(file.name());
  76.       Serial.print("\tSIZE: ");
  77.       Serial.println(file.size());
  78.     }
  79.     file = root.openNextFile();
  80.   }
  81. }
  82.
  83. void readFile(fs::FS &fs, const char *path) {
  84.   Serial.printf("Reading file: %s\r\n", path);
  85.
  86.   File file = fs.open(path);
  87.   if (!file || file.isDirectory()) {
  88.     Serial.println("- failed to open file for reading");
  89.     return;
  90.   }
  91.
  92.   Serial.println("- read from file:");
  93.   while (file.available()) {
  94.     Serial.write(file.read());
  95.   }
  96.   file.close();
  97. }
  98.
  99. void feedTheDog() {
  100.   // feed dog 0
  101.   TIMERG0.wdt_wprotect = TIMG_WDT_WKEY_VALUE;  // write enable
  102.   TIMERG0.wdt_feed = 1;                        // feed dog
  103.   TIMERG0.wdt_wprotect = 0;                    // write protect
  104.   // feed dog 1
  105.   TIMERG1.wdt_wprotect = TIMG_WDT_WKEY_VALUE;  // write enable
  106.   TIMERG1.wdt_feed = 1;                        // feed dog
  107.   TIMERG1.wdt_wprotect = 0;                    // write protect
  108. }
  109.
  110. void setup() {
  111.   pinMode(PWRKEY, OUTPUT);
  112.   digitalWrite(PWRKEY, LOW);
  113.   delay(550);
  114.   digitalWrite(PWRKEY, HIGH);
  115.
  116.   pinMode(RST_PIL, OUTPUT);
  117.   digitalWrite(RST_PIL, LOW);
  118.   delay(150);
  119.   digitalWrite(RST_PIL, HIGH);
  120.
  121.   Serial.begin(230400);
  122.   Serial1.begin(230400, SERIAL_8N1, ESP_GPIO_RX, ESP_GPIO_TX);
  123.
  124.   pinMode(2, OUTPUT);
  125.   digitalWrite(2, LOW);
  126.   delay(500);
  127.   digitalWrite(2, HIGH);
  128.
  129.   if (FORMAT_FFAT) {
  130.     FFat.format();
  131.   }
  132.   if (!FFat.begin(true)) { // Format SPIFFS if mount fails
  133.     Serial.println("SPIFFS Mount Failed");
  134.     return;
  135.   }
  136.   checkSPIFFSFreeSpace();
  137.   // listDir(FFat, "/", 0);
  138.   Serial.println("Setup complete");
  139.   Serial.println("Start Configuration of Task");
  140.
  141.   QueueHandle = xQueueCreate(QUEUE_SIZE, sizeof(DataPacket));
  142.
  143.   if (QueueHandle == NULL) {
  144.     Serial.println("Queue could not be created. Halt.");
  145.     while (1) delay(1000);
  146.   }
  147.
  148.   xTaskCreatePinnedToCore(
  149.     dataprocesa, "Task Write To Serial",
  150.     8192, NULL, 1, NULL, 0);
  151.
  152.   xTaskCreatePinnedToCore(
  153.     TaskReadFromSerial, "Task Read From Serial",
  154.     8192, NULL, 2, NULL, 1);
  155. }
  156.
  157. void loop() {
  158.   delay(1000);
  159. }
  160.
  161. void dataprocesa(void *pvParameters) {
  162.   DataPacket receivedBuffer;
  163.   int datalen = 0;
  164.   FF = FFat.open("/file.bin", FILE_WRITE);
  165.   if (!FF) {
  166.     Serial.println("Failed to open file for appending");
  167.     return;
  168.   }
  169.
  170.   for (;;) {
  171.     if (QueueHandle != NULL) {
  172.       if (xQueueReceive(QueueHandle, &receivedBuffer, portMAX_DELAY) == pdPASS) {
  173.         FF.write(receivedBuffer.data, receivedBuffer.bytesRead);
  174.       } else {
  175.         Serial.println("The `dataprocesa` was unable to receive data from the Queue");
  176.       }
  177.     }
  178.   }
  179. }
  180.
  181. void TaskReadFromSerial(void *pvParameters) {
  182.   int pcktlen = 0;
  183.   DataPacket dataBuffer;
  184.   for (;;) {
  185.     feedTheDog();
  186.     // Read one byte at a time from Serial1
  187.     while (Serial1.available()) {
  188.       String header = Serial1.readStringUntil('\n');
  189.       if (header.startsWith("+CIPRECEIVE:")) {
  190.         pcktlen = header.substring(header.lastIndexOf(',') + 1).toInt();
  191.         while (pcktlen > 0) {
  192.           dataBuffer.bytesRead = Serial1.readBytes(dataBuffer.data, min(BUFFER_SIZE, pcktlen));
  193.           pcktlen -= dataBuffer.bytesRead;
  194.
  195.           int ret = xQueueSend(QueueHandle, &dataBuffer, portMAX_DELAY);
  196.           if (ret != pdTRUE) {
  197.             Serial.println("The `TaskReadFromSerial` was unable to send data into the Queue");
  198.           }
  199.         }
  200.       }
  201.       lastSerial1Time = millis();
  202.     }
  203.
  204.     // Echo any user input from Serial to Cavli module via Serial1
  205.     while (Serial.available()) {
  206.       char c = Serial.read();
  207.       Serial1.write(c);
  208.     }
  209.
  210.     // Check for timeout to close the file
  211.     if (millis() - lastSerial1Time >= 30000) {
  212.       FF.close();  // Close the file
  213.       delay(500);
  214.       checkSPIFFSFreeSpace();
  215.       Serial.println("File closed due to Serial1 timeout.");
  216.       delay(1000);
  217.       readFile(FFat, "/file.bin");
  218.     }
  219.
  220.     vTaskDelay(1);
  221.   }
  222. }
ESP_Sprite
Re: Error while trying to update the firmware via OTA
Postby ESP_Sprite » Tue May 21, 2024 2:16 am
I split the post into its own topic as it didn't have much to do with the orighinal topic you posted this in.
For your code: I'd take a good look at line 192/193 and what happens to dataBuffer.bytesRead if the data needs to be read over multiple Serial1.readBytes iterations/
Users browsing this forum: No registered users and 78 guests
