f_getfree fails on assertion if no volume is mounted
maierkomor
Postby maierkomor » Sun May 19, 2024 2:12 pm
f_getfree calls mount_volume, which calls get_ldnumber, which crashes in lock_volume, if no volume is mounted. The crash is due to an assertion failure of an uninitialized Mutex in xQueueSemaphoreTake, called by ff_mutex_take. Both Mutex[0] and FatFs[0] seem to have an invalid pointer at that time.
pacucha42
Re: f_getfree fails on assertion if no volume is mounted
Postby pacucha42 » Mon May 20, 2024 7:43 am
Hi @maierkomor,
I assume your code looks similar to the FatFS example on the elm-chan.org site:
FATFS *fs;
DWORD fre_clust, fre_sect, tot_sect;
/* Get volume information and free clusters of drive 1 */
res = f_getfree("1:", &fre_clust, &fs);
if (res) die(res);
/* Get total sectors and free sectors */
tot_sect = (fs->n_fatent - 2) * fs->csize;
fre_sect = fre_clust * fs->csize;
/* Print the free space (assuming 512 bytes/sector) */
printf("%10lu KiB total drive space.\n%10lu KiB available.\n", tot_sect / 2, fre_sect / 2);
We have to check the f_getfree() behaviour to confirm whether the issue comes from the IDF locks incorporation to the FatFS, or from the FatFS itself. Will keep you posted, thanks for the report!
maierkomor
Postby maierkomor » Mon May 20, 2024 8:28 am
Another hint for tracking the issue down. It might be the case that a mount attempt failed before calling the f_getfree. So it might be a case, of incomplete cleanup of the relevant data-structures after a failed mount attempt.
Users browsing this forum: No registered users and 140 guests
