FAILED: esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
lladam
Postby lladam » Sat May 18, 2024 5:46 am
Hi all.
the example blink idf.py build by esp-idf-v5.2 got errors and stopped.
it was build passed by esp-idf-v4.2.
why so?
20240517 error:
C:\Users\xzy\esp\esp-idf\blink>idf.py build
Executing action: all (aliases: build)
Running cmake in directory C:\Users\xzy\esp\esp-idf\blink\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=C:\Espressif\python_env\idf5.2_py3.12_env\Scripts\python.exe -
DESP_PLATFORM=1 -DCCACHE_ENABLE=1 C:\Users\xzy\esp\esp-idf\blink"...
-- IDF_TARGET not set, using default target: esp32
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.45.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 13.2.0
-- The CXX compiler identification is GNU 13.2.0
-- Found assembler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe -
skipped
-- git describe returned 'fatal: bad revision 'HEAD''
-- Could not use 'git describe' to determine PROJECT_VER.
-- Project sdkconfig file C:/Users/xzy/esp/esp-idf/blink/sdkconfig
Loading defaults file C:/Users/xzy/esp/esp-idf/blink/sdkconfig.defaults...
-- Compiler supported targets: xtensa-esp-elf
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of time_t
-- Check size of time_t - done
-- Found Python3: C:/Espressif/python_env/idf5.2_py3.12_env/Scripts/python.exe (found version "3.12.3") found components: Interpreter
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
-- App "blink" version: 1
-- Adding linker script C:/Users/xzy/esp/esp-idf/blink/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf/blink/build/esp-idf/esp_system/ld/sections.ld.in
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/soc/esp32/ld/esp32.peripherals.ld
-- Components: app_trace app_update bootloader bootloader_support bt cmock console cxx driver efuse esp-tls esp_adc esp_app_format
esp_bootloader_format esp_coex esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota
esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_psram esp_ringbuf
esp_rom esp_system esp_timer esp_wifi espcoredump esptool_py fatfs freertos hal heap http_parser idf_test ieee802154 json log lwip main mbedtls
mqtt newlib nvs_flash nvs_sec_provider openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport
ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Users/xzy/esp/esp-idf-v5.2/components/app_trace C:/Users/xzy/esp/esp-idf-v5.2/components/app_update
C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader_support C:/Users/xzy/esp/esp-idf-
v5.2/components/bt C:/Users/xzy/esp/esp-idf-v5.2/components/cmock C:/Users/xzy/esp/esp-idf-v5.2/components/console C:/Users/xzy/esp/esp-
idf-v5.2/components/cxx C:/Users/xzy/esp/esp-idf-v5.2/components/driver C:/Users/xzy/esp/esp-idf-v5.2/components/efuse C:/Users/xzy/esp/esp-
idf-v5.2/components/esp-tls C:/Users/xzy/esp/esp-idf-v5.2/components/esp_adc C:/Users/xzy/esp/esp-idf-v5.2/components/esp_app_format
C:/Users/xzy/esp/esp-idf-v5.2/components/esp_bootloader_format C:/Users/xzy/esp/esp-idf-v5.2/components/esp_coex C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_common C:/Users/xzy/esp/esp-idf-v5.2/components/esp_eth C:/Users/xzy/esp/esp-idf-v5.2/components/esp_event
C:/Users/xzy/esp/esp-idf-v5.2/components/esp_gdbstub C:/Users/xzy/esp/esp-idf-v5.2/components/esp_hid C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_http_client C:/Users/xzy/esp/esp-idf-v5.2/components/esp_http_server C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_https_ota C:/Users/xzy/esp/esp-idf-v5.2/components/esp_https_server C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_hw_support C:/Users/xzy/esp/esp-idf-v5.2/components/esp_lcd C:/Users/xzy/esp/esp-idf-v5.2/components/esp_local_ctrl
C:/Users/xzy/esp/esp-idf-v5.2/components/esp_mm C:/Users/xzy/esp/esp-idf-v5.2/components/esp_netif C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_netif_stack C:/Users/xzy/esp/esp-idf-v5.2/components/esp_partition C:/Users/xzy/esp/esp-idf-v5.2/components/esp_phy
C:/Users/xzy/esp/esp-idf-v5.2/components/esp_pm C:/Users/xzy/esp/esp-idf-v5.2/components/esp_psram C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_ringbuf C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom C:/Users/xzy/esp/esp-idf-v5.2/components/esp_system
C:/Users/xzy/esp/esp-idf-v5.2/components/esp_timer C:/Users/xzy/esp/esp-idf-v5.2/components/esp_wifi C:/Users/xzy/esp/esp-idf-
v5.2/components/espcoredump C:/Users/xzy/esp/esp-idf-v5.2/components/esptool_py C:/Users/xzy/esp/esp-idf-v5.2/components/fatfs
C:/Users/xzy/esp/esp-idf-v5.2/components/freertos C:/Users/xzy/esp/esp-idf-v5.2/components/hal C:/Users/xzy/esp/esp-idf-v5.2/components/heap
C:/Users/xzy/esp/esp-idf-v5.2/components/http_parser C:/Users/xzy/esp/esp-idf-v5.2/components/idf_test C:/Users/xzy/esp/esp-idf-
v5.2/components/ieee802154 C:/Users/xzy/esp/esp-idf-v5.2/components/json C:/Users/xzy/esp/esp-idf-v5.2/components/log C:/Users/xzy/esp/esp-
idf-v5.2/components/lwip C:/Users/xzy/esp/esp-idf/blink/main C:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls C:/Users/xzy/esp/esp-idf-
v5.2/components/mqtt C:/Users/xzy/esp/esp-idf-v5.2/components/newlib C:/Users/xzy/esp/esp-idf-v5.2/components/nvs_flash
C:/Users/xzy/esp/esp-idf-v5.2/components/nvs_sec_provider C:/Users/xzy/esp/esp-idf-v5.2/components/openthread C:/Users/xzy/esp/esp-idf-
v5.2/components/partition_table C:/Users/xzy/esp/esp-idf-v5.2/components/perfmon C:/Users/xzy/esp/esp-idf-v5.2/components/protobuf-c
C:/Users/xzy/esp/esp-idf-v5.2/components/protocomm C:/Users/xzy/esp/esp-idf-v5.2/components/pthread C:/Users/xzy/esp/esp-idf-
v5.2/components/sdmmc C:/Users/xzy/esp/esp-idf-v5.2/components/soc C:/Users/xzy/esp/esp-idf-v5.2/components/spi_flash C:/Users/xzy/esp/esp-
idf-v5.2/components/spiffs C:/Users/xzy/esp/esp-idf-v5.2/components/tcp_transport C:/Users/xzy/esp/esp-idf-v5.2/components/ulp
C:/Users/xzy/esp/esp-idf-v5.2/components/unity C:/Users/xzy/esp/esp-idf-v5.2/components/usb C:/Users/xzy/esp/esp-idf-v5.2/components/vfs
C:/Users/xzy/esp/esp-idf-v5.2/components/wear_levelling C:/Users/xzy/esp/esp-idf-v5.2/components/wifi_provisioning C:/Users/xzy/esp/esp-idf-
v5.2/components/wpa_supplicant C:/Users/xzy/esp/esp-idf-v5.2/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/xzy/esp/esp-idf/blink/build
Running ninja in directory C:\Users\xzy\esp\esp-idf\blink\build
Executing "ninja all"...
[4/924] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[371/924] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
ccache C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=
\"v5.2.1-528-g70fc0e3037\" -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -
DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -
D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -
D_POSIX_READER_WRITER_LOCKS -IC:/Users/xzy/esp/esp-idf/blink/build/config -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_common/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/newlib/platform_include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/freertos/config/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/freertos/config/include/freertos -IC:/Users/xzy/esp/esp-idf-
v5.2/components/freertos/config/xtensa/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/freertos/FreeRTOS-Kernel/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/Users/xzy/esp/esp-idf-
v5.2/components/freertos/esp_additions/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_hw_support/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_hw_support/include/soc -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_hw_support/include/soc/esp32 -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_hw_support/port/esp32/. -IC:/Users/xzy/esp/esp-idf-v5.2/components/heap/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/log/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/soc/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/soc/esp32 -IC:/Users/xzy/esp/esp-idf-v5.2/components/soc/esp32/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/hal/platform_port/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/hal/esp32/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/hal/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_rom/include/esp32 -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom/esp32 -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_system/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_system/port/soc -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_system/port/include/private -IC:/Users/xzy/esp/esp-idf-v5.2/components/xtensa/esp32/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/xtensa/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/xtensa/deprecated_include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/lwip/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/lwip/include/apps -IC:/Users/xzy/esp/esp-idf-
v5.2/components/lwip/include/apps/sntp -IC:/Users/xzy/esp/esp-idf-v5.2/components/lwip/lwip/src/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/lwip/port/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/lwip/port/freertos/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/lwip/port/esp32xx/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/lwip/port/esp32xx/include/arch -IC:/Users/xzy/esp/esp-
idf-v5.2/components/lwip/port/esp32xx/include/sys -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/deprecated -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/analog_comparator/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/dac/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/gpio/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/gptimer/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/i2c/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/i2s/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/ledc/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/mcpwm/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/parlio/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/pcnt/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/rmt/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/sdio_slave/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/sdmmc/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/sigma_delta/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/spi/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/temperature_sensor/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/touch_sensor/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/twai/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/uart/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/driver/usb_serial_jtag/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/driver/touch_sensor/esp32/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_pm/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_ringbuf/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_adc/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_adc/interface -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_adc/esp32/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_adc/deprecated/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/efuse/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/efuse/esp32/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_http_client/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_event/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_http_server/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/http_parser -IC:/Users/xzy/esp/esp-idf-v5.2/components/bootloader_support/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/bootloader_support/bootloader_flash/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/nvs_flash/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/spi_flash/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_partition/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_wifi/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_wifi/wifi_apps/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_phy/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_phy/esp32/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_netif/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/app_update/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_app_format/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp_bootloader_format/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/wpa_supplicant/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/wpa_supplicant/port/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/wpa_supplicant/esp_supplicant/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/esp-tls -
IC:/Users/xzy/esp/esp-idf-v5.2/components/esp-tls/esp-tls-crypto -IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/port/include -
IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/mbedtls/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/mbedtls/library -
IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/esp_crt_bundle/include -IC:/Users/xzy/esp/esp-idf-
v5.2/components/mbedtls/mbedtls/3rdparty/everest/include -IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/mbedtls/3rdparty/p256-m -
IC:/Users/xzy/esp/esp-idf-v5.2/components/mbedtls/mbedtls/3rdparty/p256-m/p256-m -IC:/Users/xzy/esp/esp-idf-
v5.2/components/esp_https_ota/include -mlongcalls -Wno-frame-address  -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-
stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-
error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-
compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/Users/xzy/esp/esp-idf/blink=. -fmacro-prefix-
map=C:/Users/xzy/esp/esp-idf-v5.2=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-
declaration -MD -MT esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj -MF esp-idf\esp_common
\CMakeFiles\__idf_esp_common.dir\src\esp_err_to_name.c.obj.d -o esp-
idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj -c C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_common/src/esp_err_to_name.c
cc1.exe: error: too many filenames given; type 'cc1.exe --help' for usage
cc1.exe: fatal error: @C:\WINDOWS\TEMP\cc8cdz8a: Invalid argument
compilation terminated.
[380/924] Performing configure step for 'bootloader'
skipped
-- Bootloader project name: "bootloader" version: 1
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader/subproject/main/ld/esp32/bootloader.ld
-- Adding linker script C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader/subproject/main/ld/esp32/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp_app_format esp_bootloader_format esp_common esp_hw_support esp_rom esp_system
esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Component paths: C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader_support
C:/Users/xzy/esp/esp-idf-v5.2/components/efuse C:/Users/xzy/esp/esp-idf-v5.2/components/esp_app_format C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_bootloader_format C:/Users/xzy/esp/esp-idf-v5.2/components/esp_common C:/Users/xzy/esp/esp-idf-
v5.2/components/esp_hw_support C:/Users/xzy/esp/esp-idf-v5.2/components/esp_rom C:/Users/xzy/esp/esp-idf-v5.2/components/esp_system
C:/Users/xzy/esp/esp-idf-v5.2/components/esptool_py C:/Users/xzy/esp/esp-idf-v5.2/components/freertos C:/Users/xzy/esp/esp-idf-
v5.2/components/hal C:/Users/xzy/esp/esp-idf-v5.2/components/log C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader/subproject/main
C:/Users/xzy/esp/esp-idf-v5.2/components/bootloader/subproject/components/micro-ecc C:/Users/xzy/esp/esp-idf-v5.2/components/newlib
C:/Users/xzy/esp/esp-idf-v5.2/components/partition_table C:/Users/xzy/esp/esp-idf-v5.2/components/soc C:/Users/xzy/esp/esp-idf-
v5.2/components/spi_flash C:/Users/xzy/esp/esp-idf-v5.2/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/xzy/esp/esp-idf/blink/build/bootloader
ninja failed with exit code 1, output of the command is in the C:\Users\xzy\esp\esp-idf\blink\build\log\idf_py_stderr_output_18156 and C:\Users\xzy
\esp\esp-idf\blink\build\log\idf_py_stdout_output_18156
liaifat85
Re: FAILED: esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
Postby liaifat85 » Sat May 18, 2024 7:43 am
The detailed error message shows the build failure on esp_err_to_name.c.obj. This can be related to specific code changes or missing includes.
lladam
Postby lladam » Sat May 18, 2024 2:13 pm
what need change when update from v4.2 to v5.2?
Users browsing this forum: No registered users and 180 guests
