Hello everyone. I have four esp32-c6 boards. I found an example of esp_zigbee_cli, which allows two devices to connect. The connection commands are as follows:
INITIATOR
> bdb -r zr
> bdb -t d
> bdb -c 11
> tlk -k 00112233445566778899aabbccddeeff
> bdb -s
> bdb -i init
> bdb -a init
> bdb -a initiator
TARGET
> bdb -r zr
> bdb -t d
> bdb -c 11
> bdb -m 10
> tlk -t help
> tlk -t 60
> tlk -r help
I (47351) : RSSI threshold(default -64) of Touchlink target, which ranges from -127 to 127
I (47351) : Done
> tlk -r -54
> tlk -r get
> bdb -s
> bdb -a init
> bdb -a target
I have successfully used this code to connect two esp32-c6 devices.
Please tell me how to connect four esp32-c6 devices via the command line. Thank you in advance.
Problems with joining the zigbee network
Re: Problems with joining the zigbee network
You can try this.
Run these commands on the initiator device:
Run these commands on the first target device:
Repeat the target setup commands (step 2) on the second target device, replacing occurrences of "Device 1" with "Device 2".
Repeat the target setup commands (step 2) on the third target device, replacing occurrences of "Device 1" with "Device 3".
Repeat the target setup commands (step 2) on the fourth target device, replacing occurrences of "Device 1" with "Device 4".
> bdb -r zr
> bdb -t d
> bdb -c 11
> bdb -s
> bdb -i init
> bdb -a init
> bdb -a initiator
> bdb -r zr
> bdb -t d
> bdb -c 11
> bdb -m 10
> tlk -t help
> tlk -t 60
> tlk -r -54
> tlk -r get
> bdb -s
> bdb -a init
> bdb -a target
Thanks for the help. With this configuration, only one of the three boards is connected. Are there any other options?
Users browsing this forum: No registered users and 53 guests
