ESP-PROG JTAG ERROR
NurEng
ESP-PROG JTAG ERROR
Postby NurEng » Wed Apr 24, 2024 4:00 pm
I worked for a while with esp-prog PIO on VS .
Now when I try to upload , i get the following:
Error: Couldn't halt target before SoC reset
embedded:startup.tcl:449: Error: ** Unable to reset target **
in procedure 'program_esp'
in procedure 'program_error' called at file "C:/Users/Saad/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 93
at file "embedded:startup.tcl", line 449
*** [upload] Error 1
Could this mean that the esp-prog is deffective? I checked the connections between the esp-prog Jtag connector and the esp32 and they are correct. usb power is at 4.5V.
Any suggestion ?
Thank you
NurEng
Re: ESP-PROG JTAG ERROR
Postby NurEng » Fri Apr 26, 2024 12:16 pm
I found the reason.
Simple reset of the target
Users browsing this forum: No registered users and 178 guests
