esp32-c6 zigbee
fb_iceg
esp32-c6 zigbee
Postby fb_iceg » Wed Apr 17, 2024 1:00 am
esp-idf 5.1
zigbee-sdk,HA_on_off_light HA_on_off_switch
测试过程
1、使用esp32-c6 外带flash,测试正常
2、使用esp32-c6fh4,下载程序后出现问题
1)
I (353) coexist: coexist rom version 5b8dcfa
I (358) app_start: Starting scheduler on CPU0
I (363) main_task: Started on CPU0
I (363) main_task: Calling app_main()
None
Waiting for the device to reconnectI (373) gpio: GPIO[8]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldow
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:2
load:0x4086c410,len:0xd10
2)
I (379) main_task: Calling app_main()
I (389) phy_init: phy_version 202,b4b3263,May 17 2023,20:14:14
I (399) phy: error: chgp_cal no done!!!
error: pll_cal exceeds 2ms!!!
I (489) phy: libbtbb version: b684fcb, May 17 2023, 20:14:35
I (499) main_task: Returned from app_main()
I (509) ESP_ZB_ON_OFF_LIGHT: ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
I (509) ESP_ZB_ON_OFF_LIGHT: Initialize Zigbee stack
W (2859) ESP_ZB_ON_OFF_LIGHT: Failed to initialize Zigbee stack (status: ESP_FAIL)
fb_iceg
Re: esp32-c6 zigbee
Postby fb_iceg » Wed Apr 17, 2024 1:02 am
补充一下
3)
I (433) phy: libbtbb version: b684fcb, May 17 2023, 20:14:35
I (433) main_task: Returned from app_main()
I (443) ESP_ZB_ON_OFF_LIGHT: ZDO signal: 23, status: -1
I (443) ESP_ZB_ON_OFF_LIGHT: Zigbee stack initialized
I (443) ESP_ZB_ON_OFF_LIGHT: Start network steering
Brownout detector was triggered
Build:Sep 19 2022
rst:0xc (SW_CPU),boot:0xd (SPI_FAST_FLASH_BOOT)
Saved PC:0x4001975a
0x4001975a: software_reset_cpu in ROM
fb_iceg
Re: esp32-c6 zigbee
Postby fb_iceg » Wed Apr 17, 2024 1:18 am
原因找到了,电池供电,使用的 LDO 不合适
Users browsing this forum: No registered users and 29 guests
