Help with function pointers and xTaskCreate & xTaskCreatePinnedToCore
qheinal
Postby qheinal » Sun Mar 17, 2024 2:24 am
I want to run a task on a specific core. The code is loaded from external source. The external code just does some register moves and then an ILL instruction which causes the Illegal Instruction Exception as i intended it to. Code is loaded in IRAM btw.
This works but it dispaches it to wrong core because I set exception handlers specific for core 0 and they dont get triggered.
         void (*MainPtr)(void*);
         MainPtr = (void(*)(void*))(FunctionAddr) ; //FunctionAddr is the Address of start of code from external source in IRAM
        xTaskCreate(MainPtr,"test" ,8192, NULL, 1, NULL);
This does not work. It just restarts esp32
         xTaskCreatePinnedToCore(MainPtr,"test" ,8192, NULL, 1, NULL, 0);
This works with no issues.
         MainPtr(NULL); //Execute code
I do not know why it doesn't work for xTaskCreatePinnedToCore because manually triggering execution of code works by using function pointer
liaifat85
Re: Help with function pointers and xTaskCreate & xTaskCreatePinnedToCore
Postby liaifat85 » Sun Mar 17, 2024 10:51 am
Please check if that 'FunctionAddr' contains the correct address of the start of the code in IRAM.
chegewara
Postby chegewara » Sun Mar 17, 2024 9:11 pm
If this works, then maybe try to use some hack and call it from within a task created with xTaskCreate?
Or maybe all works fine, just code crash because task should not return and yours FunctionAddr does return.
qheinal
Postby qheinal » Tue Mar 19, 2024 1:49 am
It doesn't return its a loop. Apparently if i change the priority from 1 to 2 it works.
Users browsing this forum: Bing [Bot] and 75 guests
