How to make the provisioning proof of posession (pop) unique?
espmich
Postby espmich » Mon Mar 11, 2024 8:02 pm
The proof of posession (pop) value 'abcd1234' is hard coded in the WiFi provisioning example:
esp-idf/examples/provisioning/wifi_prov_mgr/main/app_main.c: const char *pop = "abcd1234";
When programming the chip of thousands of devices, every device will have the same pop value.
Question
How does one make the pop value of each device programmed unique?
Constraints
The pop value of a given device must be known to the person, while programming the chip.
The pop value of a given device must not change when rebooting the device.
ESP_Sprite
Re: How to make the provisioning proof of posession (pop) unique?
Postby ESP_Sprite » Tue Mar 12, 2024 2:48 am
Ideally, you'd create a new POP for each device at manufacturing time, then flash that into the chip, e.g. as a NVS partition. We have a tool for this if you need it. You'd then also e.g. print the POP on a sticker that goes on the product so the end user can read it.
Users browsing this forum: No registered users and 96 guests
