file names changed with tilda "~"
ZarZar
Postby ZarZar » Fri Mar 08, 2024 9:54 am
Hi There,
I have been trying to write to flash. I have the following entry in my CMakeLists.txt
fatfs_create_rawflash_image(storage ../site/dist FLASH_IN_PROJECT)
One of the files I have is named index-DiwrgTda.css
I use the following code to enumerate through the files.
 DIR *d;
    struct dirent *dir;
    d = opendir("/store/assets");
    if (d)
        while ((dir = readdir(d)) != NULL)
            printf("%s\n", dir->d_name);
        closedir(d);
The results seem to have changed the file name to look like the following
INDEX-~1.CSS
Hence the files are not what I expect them to be.
Any help as to why this is would be greatly appreciated.
Thanks.
ESP_Sprite
Re: file names changed with tilda "~"
Postby ESP_Sprite » Sat Mar 09, 2024 2:52 am
You probably want to turn on support for long filenames in FAT in menuconfig.
ZarZar
Postby ZarZar » Mon Mar 11, 2024 7:07 am
Support for long filenames in FAT in menuconfig is turned on.
4 files are placed on the FAT :
index.html
/assets/react-CHdo91hT.svg
/assets/index-DiwrgTda.css
/assets/index-MJNRYYyu.js
CMakeList.txt :
Listing from FAT /store/assets is :
REACT-~1.SVG
INDEX-~1.CSS
index-mjnryyyu.js
2 files have a modified name with a "~".
subory flash - disk.png (43.58 KiB) Viewed 1548 times
ESP_Sprite
Postby ESP_Sprite » Mon Mar 11, 2024 8:30 am
Weird. If you indeed get "index-mjnryyyu.js" back from the esp-idf programs listing, long filenames is working, as otherwise filenames would be limited to 8.3 characters. I have no idea why this would happen with some files but not with others.
ESP_adokitkat
Postby ESP_adokitkat » Mon Mar 11, 2024 7:33 pm
Hi, what ESP-IDF version are you using? If you can, try to update it to v5.2 to see if this persist.
ZarZar
Postby ZarZar » Thu Mar 14, 2024 7:46 am
I'm using ESP-IDF version 5.0.4.
I will try to update to 5.2 and report back.
ZarZar
Postby ZarZar » Wed Jun 12, 2024 6:09 am
Hi There,
the new version ESP-IDF 5.2.1 solved my problem with files on FAT.
The file names are now preserved.
dir flash 2.jpg (16.31 KiB) Viewed 994 times
Users browsing this forum: No registered users and 100 guests
