ESP32-C3-MINI SPI and I2C
VE3SVF
Postby VE3SVF » Fri Mar 01, 2024 2:57 am
Hi everyone!
I'm new to this forum and am looking for some help. I am working with the ESP32-C3-MINI SoC for a PCB board. I need to have SPI and I2C communication to two devices (SPI to device one, I2C to device two).
I cannot devise a pinout for these, as most of the breakout pins appear to be used for the internal SPI flash memory.
Could anyone please help?
Best,
Sasha (ham radio callsign VE3SVF)
ESP_Sprite
Re: ESP32-C3-MINI SPI and I2C
Postby ESP_Sprite » Fri Mar 01, 2024 6:41 am
You can use any (not otherwise assigned/used) pin for SPI and I2C; the ESP32-C3 has a GPIO matrix that can route those signals arbitrarily.
VE3SVF
Postby VE3SVF » Sat Mar 16, 2024 9:36 pm
Sorry for the late reply!
Does that mean that I can use *any* pin? I know there are many precautions around other ESP32 SoCs because sometimes the SPI flash is connected and some pins are used for strapping.
ESP_Sprite
Postby ESP_Sprite » Sun Mar 17, 2024 6:56 am
Yep, hence my (not otherwise used/assigned) remark. Check the datasheet for the flash pins and don't use them, also check them for bootstrap pins and see if the restrictions on those are an issue. (Also note a fair amount of bootstrap pins only have an effect after some eFuse is burned; without that they're unrestricted.)
VE3SVF
Postby VE3SVF » Sun Mar 17, 2024 12:48 pm
Sorry for my continued confusion.
By "flash pins," do you mean the USB+,USB- and RX/TX pins, used for flashing firmware?
Thank you for your understanding! :D
ESP_Sprite
Postby ESP_Sprite » Mon Mar 18, 2024 2:52 am
I mean the pins the (internal) flash is connected, again, check the datasheet. Aside from that, if you want to be able to re-flash your ESP32-C3, it's obviously good to also keep from using the pins you need to do that, yes.
Users browsing this forum: No registered users and 325 guests
