Simple Time Series Data
kongshui
Postby kongshui » Wed Feb 28, 2024 8:52 am
esp-idf V5.1
rainmaker master
I use the Swagger UI to obtain historical data for a certain parameter of the device。
I can see through the Swagger UI that the parameter is active and configured correctly.
param info:
                "data_type": "int",
                "name": "AAA",
                "properties": [
                  "read",
                  "simple_ts"
But when I used Simple Time Series Data on the Swagger UI, I encountered an error as follows
Failed to fetch.
Possible Reasons:
CORS
Network Failure
URL scheme must be "http" or "https" for CORS request.
May I ask if anyone has encountered the same problem?
kongshui
Re: Simple Time Series Data
Postby kongshui » Mon Mar 04, 2024 2:51 am
Update on the issue, I have resolved it.
The error reported by Swagger UI was because the input for "param_name" also needs to include the device name.
For example:
Device name: light
Param name: temp
In Swagger UI, "param_name" should be entered as light.temp.
At the same time, I have discovered another suspected bug: currently, Rainmaker does not support the '-' character in the device name. It causes the following error when trying to get simple TS data through Swagger UI.
  "status": "failure",
  "description": "Error getting data from DB. Please try after some time",
  "error_code": 136003
ESP_Piyush
Postby ESP_Piyush » Mon Mar 04, 2024 6:24 pm
Yes, we discovered this issue related to hyphen in device/param name last week and are working on a fix for it.
