Espressif IDE: GDB doesn't connect to OpenOCD
Nikitarc
Postby Nikitarc » Tue Feb 27, 2024 5:26 pm
I just installed Espressif Eclipse IDE with 'Windows offline installer' following this how to:
https://github.com/espressif/idf-eclips ... stallation
Windows 10
Espressif IDE V2.12.0,
ESP-IDE v5.1.2
I use an ESP32-C3
I can compile and flash the blink application. That's OK!.
But when I try to debug, the GDB displays an error during 'Starting OpenOCD':
Error in services launch sequence
Starting OpenOCD timed out.
My debugging configuration:
I checked the openocd.exe path it is OK.
What can I do to check where the problem is coming from?
Than you.
ESP_kondalkolipaka
Re: Espressif IDE: GDB doesn't connect to OpenOCD
Postby ESP_kondalkolipaka » Wed Mar 13, 2024 5:02 am
As mentioned here, please increase the OpenOCD server timeout value in the preferences and see if that helps?
You can use the troubleshooting guide if you have any futher issues.
Users browsing this forum: No registered users and 33 guests
