"make monitor" stopped working for me. After some OK lines it is sending out characters 1.5X slower than it should.
Once I had no problem with this.
Regards
Alberto
Wrong "make monitor" baudrate
Re: Wrong "make monitor" baudrate
That sounds quite unusual! Can you please give us some more details so we can diagnose/reproduce this:
Angus
- What OS are you using?
- What ESP32 hardware do you have?
- What ESP-IDF version?
- Can you give some examples of the output (good then bad), and (if possible) of the code which produces that output?
- If you run one of the simple examples (like examples/get-started/hello-world), do you see this behaviour?
Angus
26mhz/40mhz ~= 1/1.5
Ah, if that's what 1.5X means then yes that's what it is.
Check the crystal setting in "make menuconfig". If your hardware has a 26MHz crystal (Sparkfun ESP32 Thing is the most common board but there are some others) then you'll need to set this in the SDK configuration. This was not required in older versions of ESP-IDF.
Thank you, that was it. I selected "Autodetect" and everything was fine.
I would suggest to put a note about this in the "Getting Started" guide.
Regards.
Alberto
Regards.
Alberto
- ESP_krzychb
- Contact:
Love it! If we are looking for a master of a quick, hit and concise answer, nobody beats WiFiveWiFive wrote:26mhz/40mhz ~= 1/1.5
Actually there is such a note already, just above section Build and Flash. Basing on this case I think it should be rephrased and moved to section Monitor.alberto-g wrote:I would suggest to put a note about this in the "Getting Started" guide.
Users browsing this forum: No registered users and 16 guests
