Hi Team
The JTAG debugger I used was espressif's official ESP-PROG, the compilation software was VSCODE, and the connection confirmation was in accordance with TMS-TMS,TDI-TDI,TCK-TCK and TDO-TDO connections.
I am trying to use JTAG to burn the ESP32 program, but the following error occurs. How to solve this problem?
Siruis
Error occurred when using JTAG to burn the program to ESP32:libusb_handle_events() failed with LIBUSB_ERROR_IO
Re: Error occurred when using JTAG to burn the program to ESP32:libusb_handle_events() failed with LIBUSB_ERROR_IO
This error most likey caused by esp32 and JTAG adaptor connection problem.
Please check this
https://docs.espressif.com/projects/esp ... nstruction
Reference
https://github.com/espressif/openocd-esp32/issues/197
Please check this
Reference
Thank you very much for your reply. I went through the steps again, but I still couldn't. I also went to understand the solution of GitHub. Our mistakes are not the same. I use the espressif's official circuit board, and his solution is not suitable for me.ESP_kondalkolipaka wrote: ↑Fri Jan 05, 2024 11:09 amHello,
Please check this
Reference
I also found a forum response from 2019 that I think is the most similar error to mine.(https://esp32.com/viewtopic.php?f=13&t= ... 837#p49837)
I was using the WROOM module. The response said "WROOM module comes with AT command app" and the solution was to download the app in a different way. Does this mean ESP32 can't be downloaded using JTAG?
Please check this.
https://docs.espressif.com/projects/esp ... lity-issue
Let me move this thread to esp-idf group so that you will get an expert advise from the hardware point of view.
Users browsing this forum: No registered users and 116 guests
