Eclipse IDF install appears ok but Create IDF Project does nothing
wpkeenan
Postby wpkeenan » Mon Dec 25, 2023 12:24 pm
I installed eclipse and IDF 5.1.2. on Win 10. Have not used them before but I want to migrate some projects to this environment.
Eclipse appears to install OK and I can create a project etc. Added Espressif IDF, tried about 10-20 times by different methods but got a long list of errors and things that don't work. Mostly I get to the point where it all looks good but "Create a new Espressif IDF project" does nothing, like I didn't even click on the button. I played with many things for 10-15 hours but still no success. Almost ready to give up and go back to Arduino :(
Any help/hints would be appreciated.
Regards
Bill
Executing C:\Python310\python.exe D:\Espressif\esp-idf-v5.1.2\tools\idf_tools.py list
* xtensa-esp-elf-gdb: GDB for Xtensa
- 12.1_20221002 (recommended, installed)
* riscv32-esp-elf-gdb: GDB for RISC-V
* xtensa-esp32-elf: Toolchain for Xtensa (ESP32) based on GCC
- esp-12.2.0_20230208 (recommended, installed)
* xtensa-esp32s2-elf: Toolchain for Xtensa (ESP32-S2) based on GCC
* xtensa-esp32s3-elf: Toolchain for Xtensa (ESP32-S3) based on GCC
* esp-clang: Toolchain for all Espressif chips based on clang (optional)
- 15.0.0-23786128ae (recommended, installed)
* riscv32-esp-elf: Toolchain for 32-bit RISC-V based on GCC
* esp32ulp-elf: Toolchain for ESP32 ULP coprocessor
- 2.35_20220830 (recommended, installed)
* cmake: CMake build system
WARNING: tool cmake version 3.16.3 is installed, but has reported version 3.24.0
- 3.24.0 (recommended, installed)
- 3.16.3 (supported)
* openocd-esp32: OpenOCD for ESP32
- v0.12.0-esp32-20230921 (recommended, installed)
* ninja: Ninja build system
- 1.10.2 (recommended, installed)
* idf-exe: IDF wrapper tool for Windows
- 1.0.3 (recommended, installed)
* ccache: Ccache (compiler cache)
- 4.8 (recommended, installed)
* dfu-util: dfu-util (Device Firmware Upgrade Utilities)
- 0.11 (recommended, installed)
* esp-rom-elfs: ESP ROM ELFs
- 20230320 (recommended, installed)
OK
ESP_kondalkolipaka
Re: Eclipse IDF install appears ok but Create IDF Project does nothing
Postby ESP_kondalkolipaka » Tue Dec 26, 2023 11:46 am
Sorry for the inconvenience, similar issue reported here
This is now fixed our recent release IEP v2.12.0, please update your eclipse with the update site:
https://dl.espressif.com/dl/idf-eclipse ... es/latest/
Let us know if you see any issues after updating.
Users browsing this forum: No registered users and 12 guests
