Error compiling esp-AT project
vapisoft
Postby vapisoft » Thu Dec 21, 2023 9:47 am
I am using Visual Studio Code to compile the ESP-AT project.
I get a lot of errors in the MakeFiles.txt
For example in line 9:
string(TOLOWER $ENV{ESP_AT_MODULE_NAME} LOWER_NAME)
The error was that it didn't have the: OUTPUT_VARIABLE
string(TOLOWER $ENV{ESP_AT_MODULE_NAME} OUTPUT_VARIABLE LOWER_NAME)
In other lines it is more difficult to solve.
like in the following:
string(SUBSTRING "${PLATFORM_STR}" 9 ${SUBSTR_LENGTH} OUTPUT_VARIABLE PLATFORM_NAME)
How can it be?
Maybe I am using the wrong ISE (Visual Studio Code) or the wrong compiler (mingw32-gcc.exe).
esp-at
Re: Error compiling esp-AT project
Postby esp-at » Mon Jan 15, 2024 12:29 pm
ESP-AT does not support to compile by the Visual Studio Code IDE. you have to follow the guide: https://docs.espressif.com/projects/esp ... le_it.html
> you can browse the code by he VS code IDE.
please know.
Users browsing this forum: No registered users and 27 guests
