TV Params not recognized by Alexa
phantom8
Postby phantom8 » Sun Dec 10, 2023 7:37 am
I've add a TV device with Power, Volume & Mute params. These params work fine and can be controlled via ESP Rainmaker Android App. However, Alexa only recognized Power param. Both Volume & Mute params are not seen by Alexa. I also noticed that the header file esp_rmaker_standard_types.h doesn't contain the MACROS for Volume & Mute params. In fact, the ESP_RMAKER_PARAM_... macros defined are only a subset of what mentioned in this document "https://rainmaker.espressif.com/docs/st ... parameters". Appreciate for any help to get TV params working with Alexa. Thanks!
Here is the code snippet for the TV param
  // TV Device
  device = esp_rmaker_device_create(deviceName_TV, ESP_RMAKER_DEVICE_TV, NULL);
  // Add Name Param
  esp_rmaker_device_add_param(device, esp_rmaker_name_param_create(ESP_RMAKER_DEF_NAME_PARAM, deviceName_TV));
  // Add Power Param as Primary
  esp_rmaker_param_t *power_param = esp_rmaker_param_create("Power", ESP_RMAKER_PARAM_POWER, esp_rmaker_bool(true), PROP_FLAG_READ | PROP_FLAG_WRITE);
  esp_rmaker_param_add_ui_type(power_param, ESP_RMAKER_UI_TOGGLE);
  esp_rmaker_device_add_param(device, power_param);
  esp_rmaker_device_assign_primary_param(device, power_param);
  // Add Volume Param
  esp_rmaker_param_t *volume_param = esp_rmaker_param_create("Volume", "esp.param.volume", esp_rmaker_float(5.0), PROP_FLAG_READ | PROP_FLAG_WRITE);
  esp_rmaker_param_add_ui_type(volume_param, ESP_RMAKER_UI_SLIDER);
  esp_rmaker_param_add_bounds(volume_param, esp_rmaker_float(0.0), esp_rmaker_float(20.0), esp_rmaker_float(1.0));
  esp_rmaker_device_add_param(device, volume_param);
  // Add Mute Param
  esp_rmaker_param_t *mute_param = esp_rmaker_param_create("Mute", "esp.param.mute", esp_rmaker_bool(true), PROP_FLAG_READ | PROP_FLAG_WRITE);
  esp_rmaker_param_add_ui_type(mute_param, ESP_RMAKER_UI_TOGGLE);
  esp_rmaker_device_add_param(device, mute_param);
ESP_Piyush
Re: TV Params not recognized by Alexa
Postby ESP_Piyush » Wed Dec 27, 2023 11:44 am
As mentioned in the Standar device type docs, Name, Power, Media State, Media Control App Selector, Input Selector, Volume are all mandatory parameter for TV. Can you try adding these?
Users browsing this forum: No registered users and 16 guests
