HTTP server fails after a while.
hououin_kyouma
Postby hououin_kyouma » Sat Nov 18, 2023 7:33 pm
Hello I'm trying to use GET method with Telegram api.
static esp_err_t getUpdates_test (void)
    char output_buffer[MAX_HTTP_OUTPUT_BUFFER] = {0};   // Buffer to store response of http request
    // int content_length = 0;
    char _msg_update_id_append[16] = "";
    char url[512] = "";
    /* Creating the string of the url*/
    //Copy the url+TOKEN
    strcat(url, url_string);
    strcat(url, "/getUpdates?limit=1&offset=");
    sprintf(_msg_update_id_append, "%d", _msg_update_id);
    strcat(url, _msg_update_id_append);
    ESP_LOGI(TAG3, "url string es: %s", url);
    esp_http_client_config_t config = {
        .url = url,
        .transport_type = HTTP_TRANSPORT_OVER_SSL,
        .event_handler = _http_event_handler,
        .cert_pem = telegram_certificate_pem_start,
        .method = HTTP_METHOD_GET,
    ESP_LOGW(TAG3, "Iniciare");
    ESP_LOGW(TAG3, "Enviare un mensaje a un chat");
    ESP_LOGW(TAG3, "Open");
    esp_err_t err = esp_http_client_open(client, 0);
    if (err != ESP_OK)
        ESP_LOGE(TAG, "Failed to open HTTP connection: %s", esp_err_to_name(err));
        esp_http_client_cleanup(client);
    ESP_LOGI(TAG, "client connection open");
    int64_t content_length = esp_http_client_fetch_headers (client);
    ESP_LOGI(TAG, "content_length= %lld", content_length);
    int total_read_len = 0, read_len;
    char *buffer = malloc ((size_t) (content_length + (int64_t) 1));
    bzero (buffer, (size_t) (content_length + (int64_t) 1));
    if (total_read_len < content_length)
        read_len = esp_http_client_read (client, buffer, content_length);
        if (read_len <= 0)
	        ESP_LOGE(TAG, "Error read data");
	        return ESP_FAIL;
        buffer[read_len] = 0;
        ESP_LOGI(TAG, "read_len = %d", read_len);
    ESP_LOGI(TAG, "HTTP Stream reader Status = %d, content_length = %d",
	            esp_http_client_get_status_code (client),
	            (int) esp_http_client_get_content_length (client));
    free (buffer);
    err = esp_http_client_close(client);
    if (err != ESP_OK)
        ESP_LOGE(TAG, "Failed to close HTTP connection: %s", esp_err_to_name(err));
    ESP_LOGW(TAG, "Limpiare");
    ESP_LOGI(TAG, "esp_get_free_heap_size: %ld", (long)esp_get_free_heap_size ());
    return ESP_OK;
And my function is working several times. After that I get an error like below:
I (37509) Sending sendMessage: url string es: https://api.telegram.org/bot<TOKEN>/getUpdates?limit=1&offset=0
W (37509) Sending sendMessage: Iniciare
W (37519) Sending sendMessage: Enviare un mensaje a un chat
W (37519) Sending sendMessage: Open
E (38199) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x2700
I (38199) esp-tls-mbedtls: Failed to verify peer certificate!
E (38199) esp-tls: Failed to open new connection
E (38209) transport_base: Failed to open a new connection
E (38219) HTTP_CLIENT: Connection failed, sock < 0
E (38219) HTTP_CLIENT Handler: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT
I (38229) HTTP_CLIENT Handler: HTTP_EVENT_DISCONNECTED
I (38229) HTTP_CLIENT Handler: Last esp error code: 0x801a
I (38239) HTTP_CLIENT Handler: Last mbedtls failure: 0x2700
I (38239) HTTP_CLIENT Handler: client connection open
I (38249) HTTP_CLIENT Handler: content_length= -1
I (38259) HTTP_CLIENT Handler: HTTP Stream reader Status = 0, content_length = 0
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x401787b5  PS      : 0x00060530  A0      : 0x800f3b16  A1      : 0x3fff4540
0x401787b5: esp_transport_get_error_handle at D:/esp-idf/components/tcp_transport/transport.c:255 (discriminator 1)
A2      : 0x00000077  A3      : 0x3f408994  A4      : 0x3f408c4c  A5      : 0x3fff4570
A6      : 0x3fff4550  A7      : 0x0000000c  A8      : 0x8017b7f4  A9      : 0x3fff44e0
A10     : 0x0000005c  A11     : 0x3ffc0b1c  A12     : 0x3fff4550  A13     : 0x0000000c
A14     : 0xffffffff  A15     : 0x00000003  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x000000af  LBEG    : 0x4008be39  LEND    : 0x4008be49  LCOUNT  : 0xfffffffa
0x4008be39: strlen at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:84
0x4008be49: strlen at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:96
Backtrace: 0x401787b2:0x3fff4540 0x400f3b13:0x3fff4560 0x400dc019:0x3fff4590 0x400dc07b:0x3fff5060 0x40091081:0x3fff5080
0x401787b2: esp_transport_get_error_handle at D:/esp-idf/components/tcp_transport/transport.c:254
0x400f3b13: esp_http_client_close at D:/esp-idf/components/esp_http_client/esp_http_client.c:1566
0x400dc019: getUpdates_test at D:/esp32s-deneme/cam-telegram/main/main.c:1077 (discriminator 13)
0x400dc07b: http_test_task at D:/esp32s-deneme/cam-telegram/main/main.c:800
0x40091081: vPortTaskWrapper at D:/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
I could not figure it out. Why this function fails?
Thanks in advance.
MicroController
Re: HTTP server fails after a while.
Postby MicroController » Sat Nov 18, 2023 10:50 pm
    if (err != ESP_OK)
You clean up the client first, then try to close its connection.
Among other things, your code generally needs more structured error checking and handling.
mbratch
Postby mbratch » Mon Nov 20, 2023 3:42 pm
The error code means that the certificate failed verification. Are you sure your certificate is setup correctly?
hououin_kyouma
Postby hououin_kyouma » Thu Nov 30, 2023 8:31 pm
    if (err != ESP_OK)
Hi I've tried to clean up firstly. It's give an error instantly.
I (2779) Sending sendMessage: url string es: https://api.telegram.org/bot<TOKEN>/getUpdates?limit=1&offset=0
W (2789) Sending sendMessage: Iniciare
W (2799) Sending sendMessage: Enviare un mensaje a un chat
W (2799) Sending sendMessage: Open
I (2809) main_task: Returned from app_main()
I (2829) wifi:<ba-add>idx:0 (ifx:0, 7c:77:16:ac:d0:22), tid:0, ssn:5, winSize:64
I (3869) HTTP_CLIENT Handler: client connection open
I (3969) HTTP_CLIENT Handler: content_length= 23
I (3969) HTTP_CLIENT Handler: read_len = 23
I (3969) HTTP_CLIENT Handler: HTTP Stream reader Status = 200, content_length = 23
I (3969) HTTP_CLIENT Handler: HTTP_EVENT_DISCONNECTED
I (3979) HTTP_CLIENT Handler: HTTP_EVENT_DISCONNECTED
I (3979) HTTP_CLIENT Handler: Last esp error code: 0x40000de8
0x40000de8: _xtos_c_wrapper_handler in ROM
I (3989) HTTP_CLIENT Handler: Last mbedtls failure: 0x40000814
0x40000814: _xtos_l1int_handler in ROM
E (3999) HTTP_CLIENT Handler: Failed to close HTTP connection: ESP_FAIL
I (3999) HTTP_CLIENT Handler: HTTP_EVENT_DISCONNECTED
assert failed: tlsf_free tlsf.c:1119 (!block_is_free(block) && "block already marked as free")
Backtrace: 0x40081f45:0x3fff4370 0x4008e5d5:0x3fff4390 0x40096329:0x3fff43b0 0x4009377a:0x3fff44d0 0x40093614:0x3fff44f0 0x4008280e:0x3fff4510 0x40096359:0x3fff4530 0x4015eb49:0x3fff4550 0x400f3cbd:0x3fff4570 0x400dc06d:0x3fff4590 0x400dc0ab:0x3fff5060 0x40091081:0x3fff5080
0x40081f45: panic_abort at D:/esp-idf/components/esp_system/panic.c:452
0x4008e5d5: esp_system_abort at D:/esp-idf/components/esp_system/port/esp_system_chip.c:84
0x40096329: __assert_func at D:/esp-idf/components/newlib/assert.c:81
0x4009377a: tlsf_free at D:/esp-idf/components/heap/tlsf/tlsf.c:1119 (discriminator 1)
0x40093614: multi_heap_free_impl at D:/esp-idf/components/heap/multi_heap.c:231
0x4008280e: heap_caps_free at D:/esp-idf/components/heap/heap_caps.c:388
0x40096359: free at D:/esp-idf/components/newlib/heap.c:39
0x4015eb49: esp_transport_list_destroy at D:/esp-idf/components/tcp_transport/transport.c:75
0x400f3cbd: esp_http_client_cleanup at D:/esp-idf/components/esp_http_client/esp_http_client.c:858
0x400dc06d: getUpdates_test at D:/esp32s-deneme/cam-telegram/main/main.c:1089 (discriminator 3)
0x400dc0ab: http_test_task at D:/esp32s-deneme/cam-telegram/main/main.c:800
ELF file SHA256: 0668cf5805fd7871
Rebooting...
hououin_kyouma
Postby hououin_kyouma » Thu Nov 30, 2023 8:33 pm
Hi I can use POST method in sendPhoto function continuosly without any problem with same certificate. When I try to GET method it crashes after a while.
Users browsing this forum: No registered users and 84 guests
