Cannot install esp-idf V5.1.2 on VSCode
Planetary Systems
Postby Planetary Systems » Sat Nov 18, 2023 6:00 pm
Greetings
I am struggling to install the ESP-IDF on VSCODE. I have tried installing other version, where the same thing occurs. Any help would be appreciated in resolving this, as everytime I have tried running the installation, I get the following errors:
'xtensa-esp32-elf-gcc' is not recognized as an internal or external command,
operable program or batch file.
Command failed: xtensa-esp32-elf-gcc --version
Error checking xtensa-esp32-elf version
Error: Command failed: xtensa-esp32-elf-gcc --version
'riscv32-esp-elf-gdb-no-python' is not recognized as an internal or external command,
Command failed: riscv32-esp-elf-gdb-no-python --version
Error checking riscv32-esp-elf-gdb version
Error: Command failed: riscv32-esp-elf-gdb-no-python --version
'openocd' is not recognized as an internal or external command,
Command failed: openocd --version
Error checking openocd-esp32 version
Error: Command failed: openocd --version
'ninja' is not recognized as an internal or external command,
Command failed: ninja --version
Error checking ninja version
Error: Command failed: ninja --version
'ccache.exe' is not recognized as an internal or external command,
Command failed: ccache.exe --version
Error checking ccache version
Error: Command failed: ccache.exe --version
'dfu-util' is not recognized as an internal or external command,
Command failed: dfu-util --version
Error checking dfu-util version
Error: Command failed: dfu-util --version
'idf.py.exe' is not recognized as an internal or external command,
Command failed: idf.py.exe -v
Error checking idf-exe version
Error: Command failed: idf.py.exe -v
'esp32ulp-elf-as' is not recognized as an internal or external command,
Command failed: esp32ulp-elf-as --version
Error checking esp32ulp-elf version
Error: Command failed: esp32ulp-elf-as --version
'riscv32-esp-elf-gcc' is not recognized as an internal or external command,
Command failed: riscv32-esp-elf-gcc --version
Error checking riscv32-esp-elf version
Error: Command failed: riscv32-esp-elf-gcc --version
'xtensa-esp32s3-elf-gcc' is not recognized as an internal or external command,
Command failed: xtensa-esp32s3-elf-gcc --version
Error checking xtensa-esp32s3-elf version
Error: Command failed: xtensa-esp32s3-elf-gcc --version
'xtensa-esp32s2-elf-gcc' is not recognized as an internal or external command,
Command failed: xtensa-esp32s2-elf-gcc --version
Error checking xtensa-esp32s2-elf version
Error: Command failed: xtensa-esp32s2-elf-gcc --version
'xtensa-esp-elf-gdb-no-python' is not recognized as an internal or external command,
Command failed: xtensa-esp-elf-gdb-no-python --version
Error checking xtensa-esp-elf-gdb version
Error: Command failed: xtensa-esp-elf-gdb-no-python --version
ESP_bignacio
Re: Cannot install esp-idf V5.1.2 on VSCode
Postby ESP_bignacio » Mon Nov 20, 2023 10:41 am
Have you followed our setup tutorial here:
https://github.com/espressif/vscode-esp ... install.md
If you have any problems share the troubleshooting information with us to understand better the problem:
https://github.com/espressif/vscode-esp ... leshooting
Users browsing this forum: No registered users and 14 guests
