How to configure OCD on ESP32-S2-Saola-1 Rev 1.2 board in Eclipse?
RalphD
Postby RalphD » Sat Nov 18, 2023 2:27 pm
I could not find required information how to set the flashing and debug details in Eclipse IDF plugin.
The following is the result and how I set up Eclipse
Open On-Chip Debugger v0.12.0-esp32-20230921 (2023-09-21-13:40)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselecting 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1002
Info : esp_usb_jtag: capabilities descriptor set to 0x30a
Info : esp_usb_jtag: target chip id set to 2
Flashing "C:/eclipse-cpp-2023-03-R-workspace/simple/build/bootloader/bootloader.bin" at 0x1000
** program_esp input args <0x1000 verify> **
Error: esp_usb_jtag: could not find or open device!
** OpenOCD init failed **
shutdown command invoked
** Flashing Failed **
-1
Started by GNU MCU Eclipse
ESP_kondalkolipaka
Re: How to configure OCD on ESP32-S2-Saola-1 Rev 1.2 board in Eclipse?
Postby ESP_kondalkolipaka » Mon Nov 20, 2023 11:16 am
Flashing is straitforward, you can click on the `Run` button as shown in the screenshot below.
Screenshot 2023-11-20 at 4.37.22 PM.png (235.75 KiB) Viewed 32562 times
ESP32-S2-Saola-1 Rev 1.2 board doesn't have JTAG interface and hence it doesn't support OpenOCD Debugging.
https://docs.espressif.com/projects/esp ... -v1.2.html
I hope that helps.
Users browsing this forum: No registered users and 12 guests
