SPI Pinout for ESP32-WROOM-32D
HEckardt
Postby HEckardt » Wed Nov 08, 2023 11:14 am
Dear Forum,
I`m a beginner with the ESP32. I want to use in a ESP32-WROOM-32D one of the SPI peripherals as Master. As I could find in the "Exampels", there are different pre-definitiones for the different ESP32 types, in terms of pin-function and SPI-module (HSPI_HOST or SPI2_HOST):
#ifdef CONFIG_IDF_TARGET_ESP32
#define LCD_HOST    HSPI_HOST
#define PIN_NUM_MISO 25
#define PIN_NUM_MOSI 23
#define PIN_NUM_CLK  19
#define PIN_NUM_CS   22
#define PIN_NUM_DC   21
#define PIN_NUM_RST  18
#define PIN_NUM_BCKL 5
#elif defined CONFIG_IDF_TARGET_ESP32S2 || CONFIG_IDF_TARGET_ESP32S3
#define LCD_HOST    SPI2_HOST
#define PIN_NUM_MISO 37
#define PIN_NUM_MOSI 35
#define PIN_NUM_CLK  36
#define PIN_NUM_CS   45
#define PIN_NUM_DC   4
#define PIN_NUM_RST  5
#define PIN_NUM_BCKL 6
#elif defined CONFIG_IDF_TARGET_ESP32C3 || CONFIG_IDF_TARGET_ESP32C2 || CONFIG_IDF_TARGET_ESP32C6
#define PIN_NUM_MOSI 7
#define PIN_NUM_CLK  6
#define PIN_NUM_CS   10
#define PIN_NUM_DC   9
#define PIN_NUM_RST  4
#elif defined CONFIG_IDF_TARGET_ESP32H2
#define PIN_NUM_MISO 0
#define PIN_NUM_MOSI 5
#define PIN_NUM_CLK  4
#define PIN_NUM_DC   10
#define PIN_NUM_RST  11
#define PIN_NUM_BCKL 12
#endif
But when I compare these definitiones with the PinTable in the Datasheet, I could not find a match. So I have no idea, which pins should be connected to my external SPI equipment. Additional I`m a little bit confused about the contents of the
- Datasheet
- Technical Refernce Manual
From my point of view, it is quit difficult to learn, how to configure the I/O pins through the MUX/Matrix. Furthermore, for the idf.py I`m able to select the ESP32 sub-type.
So my questions:
- which pin should I select for the which pin function?
- for the idf.py should I simply select the "ESP32" as target device?
Thank you for your comments.
Greetings
Henry
MicroController
Re: SPI Pinout for ESP32-WROOM-32D
Postby MicroController » Thu Nov 09, 2023 12:08 pm
That's a common "problem". On the ESPs almost any pin can be configured to perform almost any function. That's why you often won't find a) a definitive documentation as to the function of individual pins and b) any consistency between projects as to which pins are used for what.
Indeed, datasheet and TRM aren't "how-tos". On the ESPs however, you don't handle that low-level stuff yourself; you use the "drivers" which are provided in the ESP-IDF to set up the hardware, like for SPI spi_bus_initialize(...) which lets you specify a configuration defining which pins you want to be used and then sets up everything for you.
Here you need to select the chip/SoC you have, which basically defines the CPU, irrespective of the module, board or devkit it's mounted on.
So ESP32 is indeed what you need for an ESP32-WROOM module. The different ESP32 SoC variants (ESP32, ESP32-S3, ESP32-C3,...) are pretty different hardware (CPUs), and you'll know when you bought e.g. an ESP32-S3, and the modules directly reflect the SoC in their names.
HEckardt
Postby HEckardt » Thu Nov 09, 2023 12:44 pm
Hello MicroController,
thanks for the answer. In the meantime I intensed my study and now it is for me much clearer, how it works. I found out, how to edit the "example" scripts for an adaptation to my specific needs. Thanks also for the link to the API´s and the short introduction to the ESP32 types.
So I think, I´m happy now and it is possible for me to continue my project.
Greetings Henry
Users browsing this forum: No registered users and 113 guests
