PCNT rotary encoder example producing extra pulses
flimsy
Postby flimsy » Mon Nov 06, 2023 4:22 am
I've been trying to adapt the PCNT rotary encoder example https://github.com/espressif/esp-idf/b ... /README.md, but I seem to be getting the incorrect number of pulse when calling get_counter_value. I've tried this with a few different encoders, and I get the same behavior every time. On turn of the encoder, which produces one pulse on my oscilloscope, produces from 2-4 counts from the encoder implementation. I've included my code implementation of a simple loop to poll and check for encoder position changes. The code correctly recognizes the direction of rotation, but produces too many pulses. I've also included some sample output. Is there something obvious I'm missing here?
[0;32mI (308) Rotary Encoder Pulse Tester: Initializing rotary encoder on pins 17 and 16.
[0;32mI (318) Rotary Encoder Pulse Tester: Initializing rotary encoder events.
[0;32mI (7138) Rotary Encoder Pulse Tester: Encoder position: 1
[0;32mI (7168) Rotary Encoder Pulse Tester: Encoder position: 2
[0;32mI (7178) Rotary Encoder Pulse Tester: Encoder position: 3
[0;32mI (7188) Rotary Encoder Pulse Tester: Encoder position: 4
#include "freertos/task.h"
#include "esp_log.h"
#include "rotary_encoder.h"
#define ROT_ENC_A_GPIO (17)
#define ROT_ENC_B_GPIO (16)
static const char *TAG = "Rotary Encoder Pulse Tester";
rotary_encoder_t *encoder = NULL;
int previous_encoder_position = 0;
void watch_rotary_encoder_events() {
int encoder_position;
TickType_t xLastWakeTime;
const TickType_t xFrequency = (10 / portTICK_PERIOD_MS);
ESP_LOGI(TAG, "Initializing rotary encoder events.");
xLastWakeTime = xTaskGetTickCount();
for( ;; )
vTaskDelayUntil( &xLastWakeTime, xFrequency );
encoder_position = encoder->get_counter_value(encoder);
if (encoder_position != previous_encoder_position) {
ESP_LOGI(TAG, "Previous encoder position: %d", previous_encoder_position);
previous_encoder_position = encoder_position;
void app_main() {
ESP_LOGI(TAG, "Initializing rotary encoder on pins %d and %d.", ROT_ENC_A_GPIO, ROT_ENC_B_GPIO);
rotary_encoder_config_t config = ROTARY_ENCODER_DEFAULT_CONFIG(
(rotary_encoder_dev_t)
0,
ROT_ENC_A_GPIO,
ROT_ENC_B_GPIO
ESP_ERROR_CHECK(rotary_encoder_new_ec11(&config, &encoder));
// Filter out glitch (1us)
ESP_ERROR_CHECK(encoder->set_glitch_filter(encoder, 1));
// Start encoder
ESP_ERROR_CHECK(encoder->start(encoder));
xTaskCreate(watch_rotary_encoder_events, "Watch Rotary Encoder Events", 2048, NULL, 3, NULL);
flimsy
Re: PCNT rotary encoder example producing extra pulses
Postby flimsy » Sun Nov 12, 2023 6:58 am
Been playing around with this for a week now and no progress. I've tried setting the glitch filter, but any value above 20 causes a crash with "set glitch filter failed", implying there is some undocumented upper limit to what the glitch filter can be? Would appreciate any guesses as to what is going on here. I'm using the bog standard example from ESP-IDF with a standard rotary encoder I bought off Amazon, and the very simple loop task above. The counts increase and decrease properly with direction, but I get 3 counts, sometimes 4, with every pulse from the encoder.
Users browsing this forum: Bing [Bot] and 74 guests
