I'm working in different projects that requires different versions, most specific 5.1.1, 4.4.4 and 4.3.1, the vscode extension is very useful to easily switch between them. In my old laptop i had two of them installed and working well (4.4.4 and 4.3.1) but when I was setting up the new workspace I saw that the versions are listed from 5.1.1 to 4.3.2. How can I install the version 4.3.1 again?
Vscode version: 1.83.1
Espressif-idf-plugin: 1.6.5
VSCode Extension does not show all IDF tags
Re: VSCode Extension does not show all IDF tags
Since that's a older version, it was not shown up.
If you are very particular about v4.3.1, you can always clone and use it.
https://github.com/espressif/esp-idf/re ... tag/v4.3.1
Here is the direct link with submodules
https://dl.espressif.com/dl/esp-idf/rel ... v4.3.1.zip
Then use extension command ESP-IDF: Configure ESP-IDF Extension and Select Use Existing Setup. and browse the downloaded esp-idf directory
I hope that helps
I hope that helps
Users browsing this forum: No registered users and 20 guests
