Event is not Shown on dash board
Trupal
Postby Trupal » Wed Oct 25, 2023 12:51 pm
Hello ,
I have upload the GPIO example on ESP32 S3 board. I can not show any event on the Dashboard of rainmaker cloud .what should be the reason ?
ESP_Piyush
Re: Event is not Shown on dash board
Postby ESP_Piyush » Thu Oct 26, 2023 8:38 am
The query is not clear. What event are you expecting which you are unable to see on the dashboard?
Trupal
Postby Trupal » Thu Oct 26, 2023 11:02 am
I have attached the Picture . In this picture , Event is 0 you can See properly
another Question:-
I have to send the Data to the Rainmaker cloud by using the MQTT protocol so how can I do that and one more thing where I can See the JSON on Dashboard ?
well I am new for Rainmaker so I can not find proper solution for the same.
Thank you
trupal
ESP_Piyush
Postby ESP_Piyush » Mon Oct 30, 2023 4:53 pm
Insights events will show up only if explicitly reported from your application code using ESP_DIAG_EVENT() function, a sample of which can be found here. There are no "default" events as such.
Meanwhile, JSON payloads for RainMaker are documented here. However, you never need to format/parse the JSONs anywhere as these are handled by the RainMaker core. What exactly are you looking to do?
Trupal
Postby Trupal » Tue Oct 31, 2023 4:09 am
I have to send 10 device status (ON/OFF) to rainmaker cloud in JSON format !
Thank you
Trupal
ESP_Piyush
Postby ESP_Piyush » Tue Oct 31, 2023 6:44 am
It is still not clear why you need JSON format specifically. You can see here that RainMaker allows creating multiple devices under same node. Using esp_rmaker_param_update_and_report() which you can find in all examples, you can report the state of any parameters, including the power/on-off parameter as indicated here.
Trupal
Postby Trupal » Tue Oct 31, 2023 7:07 am
okay got it.
Thank you
Users browsing this forum: No registered users and 56 guests
